Hard Shift when temperature is up
![Frown](https://montecarloforum.com/forum/images/smilies/frown.gif)
Its weird How so many People have this hard Shifting problem
I have the same thing ive had it since i pritty much ownd the car. Mine has 97 500KMS
Someone told me It could be the CAT soo i change that to a Offroad stainless. SOUNDS BETTER did not fix the problem.. Then just befor winter storage a Code came Up I think 1811 or something along those lines.. Im Also Going to try oil and change filter Also Heard that doesnt WORK either and Could be the solinods Inside the tranny witch youll have to PULL tranny Out...
Other Words Good LUCK KEEP us posted and I think i might just trade in my Monte Befor I hear the Tranny GO BOOOOOOOOOOOOOOOM. I feel sorry for the next sucker
. I already have a buddie that wants to trade his 2006 chevy 5.3 for my monte I might just have to take that offer...
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
the hard shift was fixed by simply replacing the fluid to dexron VI. it was expensive but i think worth it every cent. i also replaced the fluid filter as well. it takes 14 quarts and it is sort of easy to do. pepboys charges 135 for the labor and parts which is not bad. I paid about 75 dolars for the fluid and 15 for the filter which is just around 90. I'd recommend just go have it done at pepboys.
^^x2
also, ik this sounds kind of basic, but check your tranny fluid level. This simple step sometimes gets overlooked and we get caught up in the moment and think something is seriously wrong.
Check it after you drive around, then leave the car in park on a level surface with the motor on (still running), and check the trans dipstick. If you're low put in a half quart of drexon VI and repeat until fluid level met. It's crazy how such negative side affects can be created by something as simple as low trans fluid.
