Hard shift to R.
After my swap my car was shifting hard in just about every gear. I check the dip stick after a couple days and realize I didn't fill the trans fluid after the swap.(rookie mistake) I filled it up and every gear shifts fine except for reverse. It shifts hard and rough. Is there anything I can check to figure out the issue?
Angle as in if you parked on a hill or a slope of some sort. For instance the beginning of my driveway is a huge hill and if you park on it when you go to change the car out of "park" it will jerk out of park.
ok did you get new mounts after you did the swap alot of time doing a swap the mounts look good till more torq gets put on them. then the shifting into the other gears would happen when from a cold start or sitting on a angle or incline. check them just for kicks because they can lead to trans as well as engine trouble as in some thing binding
