Halfshaft Replacement
2004 SS
Hey guys, I ready a pretty good write up on halfshaft replacement on this site and it left me with a few questions the other write ups also didn't answer. Any help would be appreciated. Also, if this belongs in 'Tire, Rims, and Suspension,' I apologize. My issue is passenger side.
Thread I read, here.
Questions:
-It seems some people remove tie rod ends. Is this compensated for by loosening the sway bar in this write up?
-I’ve never separated a ball joint from a steering hub, is the rental tool from AutoZone pretty intuitive to figure out? Some people have expressed concern with tearing the boot?
-I’ve read there’s a retaining ring where the half shaft interfaces to the transaxle. Is that not the case with our Monte’s or is it something to address? Likewise, if we have them, are they easy to put back on? When the shaft was reinstalled into the transaxle do I just use wheel bearing grease?
Questions:
Budsjlm
FWD Tech Guides '95-'07
Oct 29, 2015 05:01 PM
Repair Guide: Front & Rear Wheel Speed Sensor Replacement
montejass
18
Aug 11, 2013 06:12 PM
Repair Guide: 6 Gen Headlight Bulbs Replacement How-to
Boost
Apr 22, 2010 03:05 PM
montejass
Jul 7, 2006 08:44 PM
rrobert05
Jul 4, 2006 06:20 PM
