had a dugh moment today
Old Nov 15, 2009 | 11:33 PM
monte07's Avatar
Red face had a dugh moment today
on the 3.5l engin there is a vvt type and a non vvt type. there is a vvt type like the 3.9l and there is just a normale typr wich one is it? is the vvt type 3.5 the e85 type or the non? for some dumb reson i had a brain fart about it and it is really bugging my about it and i know i can remember but sume reson a brain fart and cant think about wich one is wich for some reson.
Old Nov 15, 2009 | 11:37 PM
Budsjlm's Avatar
Umm what?
Old Nov 15, 2009 | 11:53 PM
from what you've said in the past, you have a 3.5 e85 vehicle, right, what is the problem???
Old Nov 15, 2009 | 11:55 PM
i don't believe the 3.9 was e85, maybe on another make or model, but not on the chevy 3.9. do you have a flexfuel sticker on the back of your car??
Old Nov 16, 2009 | 12:23 AM
Wilco's Avatar
If you had an impala/impala police package 08-09 with a 3.9, it came with the ffv option. MC's 3.5 06-07 came with it too.
Old Nov 16, 2009 | 10:20 AM
monte07's Avatar
acording to milzy motorsports and zzperformance. the 3.5l v6 came with two options a variable valve timing and a non vvt type of engine. the 3.9 they said is also a vvt thats what they said. i have a flex fuel model which is different injectors to run the different fuel which they are bigger. different program to run e85 and regular in the computer. also different knock sensor do to the e85 will make a car knock if that isnt changed. do to the higher burn rate. i dont know what they were saying is it the vvt or non vvt i was looking for parts to see if they will fit
Old Nov 16, 2009 | 11:21 AM
Wilco's Avatar
http://www.e85fuel.com/information/f...vs_1.13.09.pdf
These are the engines, by year and model, that came with the e85 options. It's going to cost some money to change your engine to take e85. Have you check to see e85 availability in your area? It would be messed up for you to change your car to e85 and end up with no gas station near you that carries ethanol fuel.
Old Nov 16, 2009 | 01:48 PM
MAMONTE's Avatar
ALL of the 06-07 Monte Carlo's with the 3.5L V6 were the 3.5L 3500 V6 with VVT! The non-VVT version was in other GM cars like the G6, and minivans for a while.
Old Nov 16, 2009 | 09:03 PM
monte07's Avatar
so why did gm do that? so that makes it imposible for the 06-07 ro get headers for it then?
Old Nov 16, 2009 | 09:27 PM
mrl390's Avatar
Why would it be impossible to get headers? The only thing that determines if you can get headers is if someone actually makes them or not, not if your engine is VVT or E85 compatible. The headers would be vehicle specific anyway so just because they use a non VVT engine in the other cars, doesnt make it any less likely to get headers made for a 3.5 monte.
