Engine wiring harness - 1985 SS
I have a 1985 monte carlo SS that needs the engine wiring harness replaced from the ECM out to the engine covering all sensors.
Should I go with a replacement harness or is there an aftermarket setup that also replaces the ECM?
If so, where do I get either option?
Thanks.
Thanks.
you can try here, I hope it helps!
http://www.mikesmontes.com/index.asp
Product ID: 1219
Used Engine Headlight Wiring Harness
Details
Used Engine Headlight Wiring Harness. Everything needed for engine, lights on front end, and transmission. Complete up to harness plug on firewall.V-8 1984-1988
Price: $199.00
Product ID: 1219Used Engine Headlight Wiring Harness
Details
Price: $199.00
thanks for following up on this
, glad I was able to help
gotit4cheap16
Jul 29, 2010 08:12 AM
