engine problems 305
Old Jun 16, 2011 | 02:22 PM
78montecarlo's Avatar
Default engine problems 305
I trying to figure out what wrong with the engine , I have to put collant every time I used my 78 monte carlo, i was looking for a leak or something but aint no leak , now is over heating , I replace thermosta but still over heating .
Any help will be helpful?
Old Jun 16, 2011 | 02:33 PM
Budsjlm's Avatar
sounds like a blown head or intake gasket, pull out your dipstick if it looks like a milk shake you have a problem stop driving it's time to tear into it! , any smoke out the exhaust? do a compression check and see if any of the cylenders a really down on thier numbers
Old Jun 16, 2011 | 03:02 PM
the oil look good is not mix with water yet, and yes sometimes white smoke come out the exhaust, compression is low
Old Jun 16, 2011 | 04:47 PM
Budsjlm's Avatar
is it low across the board or just certian cyl
Old Jul 8, 2011 | 05:08 AM
finallyss's Avatar
If you have white smoke, you have water leaking into cylinder, or making it's way into cylinder.
Make sure it's white smoke and not light blue. Light blue smoke is oil burning.
Gunar
Jun 29, 2010 03:12 PM
adamlessor
Jun 22, 2009 12:16 PM
shaggygod
Sep 11, 2007 11:33 AM
1984monte
May 18, 2007 06:41 PM
steptoe
Nov 26, 2006 11:38 AM
