Engine mounts noise
Old Oct 26, 2011 | 11:38 AM
00SSsupercharged's Avatar
Default Engine mounts noise
I'm haveing some problem every time I come to a stop. All I'm hearing is clicking noises. What I think the problem is the engine mount. I tried tightening up the bolts (which the bolts were tight from before). So after I tightened them up the noise stoped for a small period of time then it came back... Would anybody happen to know how solve this problem?
Old Oct 26, 2011 | 12:42 PM
nitehawkjcb's Avatar
Which mount? The one by the crank pulley or the dogbones up top? You might need new ones
Old Oct 27, 2011 | 01:12 AM
I really don't know where its coming from exactly. But how would you know where would it come from?
Old Oct 27, 2011 | 10:43 AM
Try to rock the engine back and forth and see which one is loose
Old Oct 27, 2011 | 10:59 AM
You may also have a caliper issue. Can you jack the car up and spin the tires by hand and have a listen?
Old Oct 27, 2011 | 01:27 PM
Good thinkin Chibi
I try
Old Oct 30, 2011 | 07:37 PM
I doubt it's the caliper. I'm hearing the noise directly from the hood...
I know what's the problem its the the motor mount. The "dogbone" they call needs to replace.... Anyone selling it here? Or is it mandatory to buy one?
Old Oct 30, 2011 | 10:41 PM
I doubt anyone on here is selling one, try ebay, or at worst, your local GM stealership
Griffindor
Aug 19, 2013 04:42 PM
Mota1983
Aug 16, 2013 06:46 PM
01 Monte SS
Jan 9, 2013 04:51 PM
Justin Knight
Apr 12, 2010 08:36 PM
Steven73
Nov 23, 2009 01:12 PM
