Engine Knock and Transmission Wont Shift
Old Jun 18, 2010 | 04:06 AM
Visceron's Avatar
Default Engine Knock and Transmission Wont Shift
I finally got my car up and running after the Dizzy problem and now I got more problems. When I accelerate, I hit about 30 MPH and the car will not shift into the next gear. When I floor it, I hear a slight knocking from what I believe is the bottom of the engine. Might be a bent rod or something, but I am more worried about the tranny because I dont know how to fix those yet. Also, my kickdown cable has not been connected just yet. it wont work with my bracket.
Old Jun 18, 2010 | 08:26 AM
Year, Model, Engine, Miles, etc.
Could be something simple as a clogged Cat
Old Jun 18, 2010 | 09:15 AM
03SS/00GSE/93LX's Avatar
This smells like a SBC/TH350 combo to me. I'm no expert on old school stuff like that, but weren't those older automatic transmissions heavily vacuum dependent (thinking: vacuum modulator, etc)? If so, are all of your vacuum lines properly connected/not leaking?
Old Jun 19, 2010 | 06:00 AM
Visceron's Avatar
Good point. I saw a vacuum line from the transmission not connected. I will **** with that tomorrow
Old Jun 20, 2010 | 11:26 AM
Visceron's Avatar
Fixed. 03SS/00GSE/93LX, I renounce god and will now pray to you :P Vacuum line was not even there. Got it to work after connecting the vacuum line.
scypher23
Jan 26, 2013 05:21 PM
silvermike19
Dec 15, 2011 05:54 PM
matrx10503
Dec 6, 2011 11:11 PM
Skeletal Crow
Jul 21, 2011 12:30 PM
laredoggg
Nov 10, 2006 07:34 PM
