Ebay Turbos
Old May 6, 2014 | 09:33 PM
Jake Long's Avatar
Originally Posted by ZIPPY02
My $1200 Precision turbo was bought off of eBay and it lasted for over 4 years, finally died when some exhaust manifold fragments went through it.
There are reputable authorized brand name sellers on eBay for Turbonetic's, Precision, Holset, Borg-Warner, Garrett on eBay. Not everything is going to be Chinese knock off marginal equipment.
You just have to pay attention to the seller and his being an authorized seller. Many have actual stores and eBay accounts, the same as Summit, Jegs etc. as another venue to sell their products. Just pay attention to the if it seems too good to be true gut feeling.
$1200 is not something I want to spend on a trial run. How would one go about making sure the manifold doesnt start following apart.
Old May 7, 2014 | 06:55 AM
vikesfan's Avatar
Originally Posted by red04montels
Do you speak from experience or opinion?
I've seen some actual decent results on ebay turbo's when done right.
Would I build with an ebay turbo? No, does that mean it can't be done? No.
experience.
i had a cheap turbo on a old vw gti when the stock when finally gave up.
the cheap chinese turbo didnt even last a month before the compressor wheel decided to fall apart and shoot metal chunks throughout my engine.
needless to say, that $175 ebay turbo ended up costing me over $2000
also, you say the setups you have seen had decent results? when you say results, do you mean putting down power or having the turbo last more than a few months?
i have rarely, if ever, seen one last more than a year on a working, daily driving, non drag car.
would i throw a cheap turbo on a busted civic? you bet your *** i would.
would i throw one on a car worth more than $2000? never again.
Old May 7, 2014 | 07:07 AM
vikesfan's Avatar
Originally Posted by Jake Long
I can weld no problem. So there is no way of getting a $200 turbo setup? I have 0 experience with them so thats why I want to get a cheap one. TBH I don't even want it to give me a noticeable boost. Just want to try to install it and see if it actually works without blowing up the engine. Experience is everything.
there is absolutely, no way in the world you will only spend $200 for the entire turbo kit.
consider this build sheet list that you have to have.....
turbo
wastegate (if not already integrated into the turbo, i dont recommend that type of wastegate since they leak badly)
blow off valve
intercooler (not required, but dumb if you dont)
intercooler/charge pipe
silicone couplers
header flanges (if making your own)
exhaust header tubing
custom crossover tubing
turbo inlet flange
turbo outlet flange
exhaust tubing from turbo exit to standard exhaust
upgrading your exhaust to 3" or larger
mufflers
larger fuel injectors
fuel pump (not needed but recommended)
boost gauge
gauge pod
misc hoses, brass fittings, clamps, etc etc etc
then on top of all that, which i am sure i am missing something, you will need to tune it.
that requires a purchase of HPTuners or an old DHP PowrTuner or you can buy a canned tune from a vendor (which is NOT recommended at all, do your own tuning). I have no idea the going rate for these tuning options, but lets just say, this by itself, will be more expensive than your chinese turbo you would buy.
like someone else said, if you could turbo our cars for $200, everyone would do it. there are some pretty talented people that have been messing around with our cars and engine for ~15 years.
there should be nothing that hasnt already been tried and tested, and i am sure there are some pretty janky turbo set ups that have been done, NONE of them only cost $200.
Old May 7, 2014 | 07:08 AM
vikesfan's Avatar
also, to the OP....
based on your questions and comments, i would seriously do a LOT more, and i mean a LOT MORE research on turbo set ups.
Old May 7, 2014 | 10:03 PM
I don't see any way that would be even remotely possible, the cheapest turbo I found on ebay was $140. So you're going to have to get all of the other materials for $60? I just don't see any way you could do that between flanges, all the piping, some way to tune the car, etc.
I think you might be able to squeeze in a setup for $500 if you do all the work yourself, and buy a full turbo 'kit' off ebay that has all of your clamps and plumbing and such that you just need to cut and weld into place. But you'll still have to get someone to tune your pcm for free/cheap.
As an alternative to a Chinese turbo, you could always get a used junkyard OEM turbo. Stock turbos are typically very reliable, and cheap as people upgrade to aftermarket ones.
Old May 8, 2014 | 03:27 PM
6cylofun's Avatar
Yeah I have seen those $500 turbo kits on Ebay. I wouldn't install them on any engine I didn't want to grenade in a few months(at best).
If I had the disposable income and time I suppose it would be fun to install it on a junker just for a few laughs.
Old Jan 6, 2015 | 07:11 PM
Jake Long's Avatar
Ok. So I put a lot of thought into this and am planning on doing this.
1. Turbo Kit - GT T3 T4 T3 T4 T04E Universal Turbo Charger Kit Wastegate Intercooler Piping | eBay
2. Cross Over - ZZPerformance - Turbo Crossover #ZZ-TXOVR
3. PCM
That should be everything I need right? or am I missing a lot of stuff?
Old Jan 6, 2015 | 11:05 PM
3. PCM
What about fuel? Depending how much boost you plan to run, the stock NA injectors are pretty tiny (22# IIRC). To add some headroom, you could always pick up some used L67 injectors. They flow about 50% more, and can be had for under $50 used or ~$150 cleaned/checked.
As you've probably seen, this has evolved way beyond a $200 setup. If you go with the Z3 crossover, you're almost $800, and if you get a Z7 or Stattama crossover, you'll be at $1000. For that kind of money, you're getting close to the price of complete used turbo kits. Many of the used kits go for well under $2k now- some even in the mid-low $1000s.
I realize that's more than you're looking to spend by a little bit, but that would also be 100% bolt on with no fab time at all and a quality turbo.
I'm all for wanting to DIY it, I definitely get it, just trying to make sure you understand all of the options.
04MonteLS
May 10, 2010 05:07 PM
04MonteLS
Apr 20, 2008 07:37 AM
mickey
Jan 28, 2007 04:56 PM
medirtypaws
Dec 18, 2006 10:17 PM
malletboy
May 20, 2006 01:02 AM
