eBay/obx headers on 95-99 monte
eBay/obx headers on 95-99 monte.... Besides fire wall what else needs to be done?
I have seen pics of the fire wall being pounded to .... But is there anything else that needs to be done? Longer o2 wires? Diff clamps? Ect...
I have the DPP headers on my 96, which are SLP knockoffs/similar to speed daddys, etc. I will say that 'pouding' doesn't even remotely begin to explain it. Where my headers landed- they sat totally though both firewall layers into the passenger compartment where that little hump is in the firewall.
I had to pound a bit up top, mostly for extra clearance for engine movement/heat issues (since I had to remove the firewall shield, and the headers are bare/not wrapped or coated); cut out a notch for the O2 sensor, and cut out maybe a 6" wide x 10" long hole through both layers of firewall.
Maybe other brands are different, but it certainly was far from a drop in. Other than that, it went smooth- O2 wires were long enough- but I did go with those wide band clamps (the ~2" wide ones) instead of the garbage that came with it, and still had to fight with leaks a bit.
Honestly, I don't recommend headers to anyone on a 5th gen unless they're SC'd.
Hey bumpin, my DOHC might have jumped timing if it did it's not worth fixing a 225,000 mike motor. So that means a swap to a l36 and topswap. Where I want to take the setup headers are deff a must. Do you think cutting and rewelding the headers will help? What part of the exhaust hits the firewall? Maybe I can relocate the O2 as I will need an extra bung for my wideband anyway.
well since my DOHC engine died i have to get the car running asap. so i will be installing the l36 first. it will have headers and my full exhaust that i currently have on the car and my FWI. i have the 180* stat and plugs are cheep. after the engines 90 day warranty i will be installing the topswap kit. those 90 days will give me time to port the heads, lower intake, and blower, gasket match everything, and fit a north star TB to it. then, i will tune the heck out of it.
next phase after that will be rockers or a cam and then a pulley drop.
The idea is to get it back on the road ASAP. no time to do the cam. nor time to do the topswap right now. i will take some time and port all the topswap stuff so when it goes it it will be ready.
i figure down the road i will do rockers, and if i need more then small intercooler.
the build currently will be as follows:
-L36 high compression block
-4t65e with 3.29's
-L67 tops wap
-my 3" MAF
-North star TB
-Ported: blower (inlet and outlet), Lower intake, heads
-Speed daddy headers
-my current 2.5" high flow exhaust with high flow cat and magnaflow straight thru muffler
add to that some quality tuning.
It should make for one heck of a ride. my current goals for once the SC is on is to get to 14 flat. my ultimate goal is for 13 flat or just inside of 12's
-4t65e with 3.29's
-L67 tops wap
-my 3" MAF
-North star TB
