Easiest way to drop the tranny?
Old 09-17-2010, 08:45 PM
jhornekm's Avatar
Default Easiest way to drop the tranny?
We are swapping trannys tomorrow on my 00 Monte Carlo. What is the best way to do this. We have never done any work on a Monte Carlo before?? Any help would be greatly appreciated. Thanks to all
Old 09-18-2010, 01:32 AM
wow you are in for a treat my friend, there no way i could explain this with a keyboard. you better have alot of patience and a box of bandaids.
Old 09-18-2010, 12:01 PM
there are some things that need to be removed befor detatching the trans like the cv shafts as well if there in the way the power steering lines as well as the rack and pinion. i just wanted to give you a heads up as to plan the way of attack.
Old 09-18-2010, 12:51 PM
and the undercarriage, and the wheel assembly's, and the list goes on and on and on. im very good mechanically, i helped a buddy change out a tranny in 03 grand prix and well im just gonna save up and let someone replace mine for me in febuary.
Old 09-18-2010, 04:12 PM
You have take it out with the engine and subframe, through the bottom, its not too bad with a lift, I've done it at work on several car (i'm a mechanic), I don't have a clue how to do it without a lift though
Old 09-18-2010, 05:31 PM
ratchet strape and a 4x4 across the strut towers, dangerous but only way. your right your suppose to just unhook the engine and subframe and just lift the car up off the engine and tranny and then disassemble. if you havent worked on cars your whole life you should not attempt tranny swap, alot can go wrong, especially if your tryin it in your drive way.
Old 09-18-2010, 08:34 PM
jhornekm's Avatar
It took all day, but we got it out with a motor hoist. The engine and tranny came out together through the top. Now we just have to put it all back together. Fun huh??
Old 09-18-2010, 10:19 PM
hell ya. good job man. how much fun did you have gettin the one bolt out that sets in between the tranny and the motor. me and my buddy had to use like 6 extensions.
Old 09-18-2010, 11:29 PM
good wrenching I't will feel good when it's done knowing you did it yourself.
Old 09-19-2010, 08:20 PM
jhornekm's Avatar
I did not to do. My hubby did it. I of course did help take a few bolts out here and there and.... mostly watch! I helped him lower the engine and tranny in. So just a few more bolts and wires and put the axle back in and we should have her running. It is just getting more exciting.
Quick Reply: Easiest way to drop the tranny?
