downstream O2
Old Jul 3, 2012 | 10:08 AM
04IntimidatorSS's Avatar
Default downstream O2
I had my zzp dp installed awhile back and I noticed the other day the o2 sensor was put in on an angle an they stripped the threads of the o2 and the bung. So I took out the o2 and Installed a plug in there and my CEL light came on...The car runs fine but that wont effect at all correct?
Old Jul 3, 2012 | 10:18 AM
Worst case senario:
Youll lose some fuel mileage...
Thats my knowledge of the CEL being activated from a bad or "missing" O2 sensor.
Old Jul 3, 2012 | 10:24 AM
That o2 sensor doesn't give the PCM any readings to adjust air/fuel ratio.
Shouldn't affect your car's performance, just is telling you that the cat isn't operating correctly (which a high-flow usually throws anyway)
Old Jul 3, 2012 | 10:33 AM
Thanks for the correction!
Nice to know we have such people here to get the precise info...
(we did have 1 that failed on the mrs blazer)
and her fuel mileage dropped off drastically..
Old Jul 3, 2012 | 10:40 AM
For our cars, only the front bank o2 sensor (on the rear exhaust manifold) works with the MAF sensor and the PCM to adjust air/fuel ratios.
That 2nd o2 sensor ONLY monitors the effectiveness of the Cat and will throw the P0420 code if it feels the Cat is not operating correctly. Simply tune out that code and live life happy.
Old Jul 3, 2012 | 11:25 AM
I'd be mad as heck that a shop installed it and stripped the threads. Man, that thing should have been super easy.
But Chibi is right, the downstream O2 is just to check the CAT, no performance/fuel issues and it can be tuned out of the PCM not to throw the code.
Verify your local emissions rules though, I've heard some places have been known to check the system for a cat AND the rear O2 sensor!!
Old Jul 3, 2012 | 08:03 PM
awesome, thanks guys
Old Jul 6, 2012 | 09:06 PM
z34phoenix's Avatar
this is not 100% correct. there are some cars that when the rear O2 is removed, even when the code is removed from the pcm that have issues. it deals with a cat efficiency test. the car will rapidly throw more fuel to test the cat and will look at the rear sensor for a change in data. this causes the fuel trims to peg and noticeably hurt mpg. the only solution that i have heard is to have this test set to 0 runs vs the 6 it is set to stock. again this is not an issue on all cars... but some do react this way.
Old Jul 6, 2012 | 11:43 PM
That is true, but that's why as Chibi said "for our cars" and explained the up and down stream O2 purposes. On our Montes, the downstream O2 affects nothing with emissions, fuel efficiency, drivability. It's there for a "health check" on the cat and nothing more.
Old Jul 7, 2012 | 05:44 AM
z34phoenix's Avatar
No when I said some cars I ment to say some monte/GrandPrix have this issue. It is not all of them IIRC it was 2002+ that had the cat efficiency check. You won't get any engine lights the only way you would know there is a problem is if you are scanning and see te trims go to hell for no reason.
