Distributor problems 74 Monte
Did you check to see if you have spark? Did you set the dwell on the points? Also. did you have a hard time trying to get the cap back on? If you did, its possible that you have the rotor 180* out. Also check your firing order.
One more thing that did happen to me once.
Check to see if the wire coming from the coil to the dist is still in tact. I had a hard time trying to get my Apache started and found the wire was only held together by only the sheath. Replaced the wire and it fired right back up.
Kracktheskye
Mar 2, 2011 03:52 PM
mhallen13
Sep 12, 2010 03:26 AM
Cobramen
May 25, 2005 01:06 PM
