Opinion Needed: Cuts out
Old May 12, 2017 | 03:33 PM
Dyl's Avatar
Dyl
Default Cuts out
I have a 06 monte carlo ss.........if you don't accelerate slowly it wants to cut out, does anyone have any suggestions on where to start looking for the problem?
Old May 16, 2017 | 08:10 AM
farmerjg's Avatar
Do you have any engine codes? I'd start your troubleshooting around your throttle body and the associated sensors. Out of curiosity, is it anytime you slam open the throttle? So, if you're cruising on the interstate going 70 and you floor it, does it do the same thing as when you do it from idle or a stop?
Old May 16, 2017 | 11:57 AM
Dyl's Avatar
Dyl
Do you by chance happen to know what sensors are located around the throttle body?
Old May 16, 2017 | 02:23 PM
Define the area around the TB, because doesn't the LS4 just have the throttle position sensor attached to the TB?
Old May 16, 2017 | 03:13 PM
Dyl's Avatar
Dyl
Thats what I was thinking as well
