cut our
hey guys im kinda new to the forums but yeah i have a 05 monte all engine is stock but i was wanting to know if u think getting a cut out with a stock exhaust would be worth it or should i just save up get the system then cut outs or are cut outs even worth it
I would steer clear of cut outs myself.
Our NA 3.8L's require some back pressure or you end up loosing out on HP through the mid to upper RPM range.
I already have flowmaster 40's, but I am going to have the U bend eliminated and the resonator replaced with a glass pack or a racing muffler. BTW, rummor has it the factory mufflers on the 3.8L are no more restrictive than flows. So unless your swapping out mufflers for sound I would stick with the factory mufflers... Ok, ingnore all that jumbo, the flows sound really nice..
TVW
TVW
ORIGINAL: tvanwinklehome
A cut out is a valve of sorts that dumps the exhaust right after the manifolds before it runs through the cat.
TVW
TVW
monte83
Sep 12, 2006 06:04 PM
