Crankcase Valve
Old Sep 25, 2008 | 02:52 PM
vikinghaux's Avatar
Default Crankcase Valve
well i replaced my LIM gasket last night and got everything back together. Somewhere along the way the crankcase valve (I believe this it what it is called) fell off and is lost in a black hole somewhere. I've been searching trying to find a part number but can't seem to find anything. Can anybody help me out?
Old Sep 25, 2008 | 05:06 PM
mrl390's Avatar
Default RE: Crankcase Valve
Are you talking about the valve in the valve cover that is connected to the intake? Its called the PCV valve. Try searching using that name.
Old Sep 25, 2008 | 05:46 PM
vikinghaux's Avatar
Yes that's what I'm talking about. I looked at the illustrations at gmparts.com and couldn't find the part I was looking for anywhere. What system is it part of? The EGR?
Old Sep 25, 2008 | 09:06 PM
mrl390's Avatar
No, its just part of the emmissions. It opens when pressure builds up in the crankcase and lets out the gases emmitted from blowby and hot oil inside the crankcase. The suction from the intake draws the gases out of the crankcase and back into the cylinders to be burnt again, then when pressure is equalized, it closes again.
Old Sep 25, 2008 | 09:11 PM
mrl390's Avatar
Assuming you have a monte with the 3.8, I found this. This is the only site I looked on but advance auto, carquest, autozone, ect should have the same parts:
http://www.napaonline.com/MasterPage...on+(PCV)+Valve
Old Sep 25, 2008 | 10:47 PM
vikinghaux's Avatar
Ok well I looked at what you're talking about. Thats what I need I'll have to go pick one up tomorrow. Thanks for your help
Old Sep 26, 2008 | 03:09 AM
mrl390's Avatar
No problem
BeachBumMike
Jul 20, 2007 03:50 PM
mentiroso
Oct 6, 2006 08:48 AM
Ca$$e
Jul 25, 2005 02:13 PM
blink916
Mar 1, 2005 03:33 PM
adreed24
Feb 10, 2005 02:24 AM
