Crank Shaft blew out
but if it was the alternator, the car would've turned on when we put the new battery inside. The battery wouldn't have lasted so long though, because it wouldn't have been getting any charge from the alternator.
the reson why i said scratch and mentioned the others. is you have 15-30 minutes of run time when a alternator goes bad. also the other battery could have not been up to snuff what i mean have 12 volts and 5ca(cranking amps) and 3cca (cold cranking amps) and didnt have enough to start it there is a safty program in the computer that prevents any damage to the engin and its electrical when there is a problem like a voltage and voltage and mechanical issue. i would check every thing out as in take your battery to auto zone have them check and charge it and see if it starts. then if it does rent a belt tentioner tool remove the altinator and have it checked. i am sorry if i sound angery i dont want to see some one getting ripped from a shop claming it is the engine when they put it together from head work. unless they seen internal damage on the cylender walls when they did it and seen some one that they can get money from dont forget lemon laws. on top of that chevy has a 100,000 mile 10 year power train warrenty take it to the chevy dealer. if it is under 100k take it to the dealer and they will fix the engine and power train. i just want to look out and meantion that
the oil level was where it should be, although, it was pretty dirty.i was planning on doing a tune up on it the same weekend that this happened.and i have no idea how it ran on hot.never really drove it that long. 2 of my friends had told me once that the pistons sounded like they were knocking as i drove away?idk if that helps at all?
also, if it did seize up due to oil starvation, will it still be the crank shaft or something else?
sounded like the oil pump went out and didnt create enough oil pressure. but the oil gage now a days cars have idiot gages as in look like they are working and run by voltage.
Have you tried turning over the engine by hand?
ok sorry i took so long to write back guys.I've been focusing on getting my monte running again. Well so far, we've taken out the engine and when we removed the oil pan, there was a bunch of broken metal. A piston, rods, crankshift and basically the whole core was shatter. So now im looking for an engine or a new core.
does anyone know if a 98/99 oldsmobile 3800 engine can be a direct swap for my monte? A dismantler is selling one for 400 and so far thats the only one ive found in my price range.
hay bumpin i didnt know the oil pump for the 3800 were set up like that thanks for the info. i never opened up a 3800 they are pretty much reliable and also pretty potent stock when they are loved. i have seen most be pretty beaten but still be running like nothing is wrong. sorry for changing the thread
so bumpin96 was right. The engine was already toast since i got it.
The whole bottom end was f'd and in pieces due low oil pressure or the oil pressure went out
i went to a nearby junkyard and found a 3800 engine from an impala w/out the intake manifold and a few other parts and it costed me around $200 with 1 yr warranty
we replaced all the gaskets and degreased the whole engine
and i barely got my car back right now and it runs like a champ!
I'm so happy!
i will post pics of the process a little later
Thank you everyone for your help and support!
I'm so happy!
MJClemm
10-09-2022 10:13 AM
ltrain925
12-22-2009 12:39 PM
01blackmonte
10-17-2005 08:30 PM
