Compression test
Old Mar 25, 2014 | 12:02 PM
Heres some tech specs I found on the series II 3800!
Engine Specifications
1993 - 19951995 - 199819992000 - 2001TypeL32L36 3800 Series IIL36 3800 Series IIL36 3800 Series IIConfigurationOHV 60° V6OHV 90° V6OHV 90° V6OHV 90° V6Displacement3.4L (204 ci)3.8L (231 ci)3.8L (231 ci)3.8L (231 ci)Engine BlockCast IronCast IronCast IronCast IronBore3.62 in3.8 in (96.52 mm)3.8 in (96.52 mm)3.8 in (96.52 mm)Stroke3.31 in3.4 in (86.36 mm)3.4 in (86.36 mm)3.4 in (86.36 mm)Compression Ratio9.0:19.4:19.4:19.4:1Firing Order1-2-3-4-5-61-6-5-4-3-21-6-5-4-3-21-6-5-4-3-2 Fuel87 octane87 octane87 octane87 octaneFuel SystemSFISFISFISFIFuel Pressure? psi (ignition ON)
3-10 psi loss at idle48-55 psi (ignition ON)
3-10 psi loss at idleInjector Size17 lbs (AC Delco 217-301)22 lbs (AC Delco 217-306)22 lbs (AC Delco 217-306)22 lbs (AC Delco 217-1436) Cylinder HeadsCast IronCast IronCast IronCast IronCombustion Chamber?64 cc64 cc64 ccIntake Valve1.720 in1.800 in1.800 in1.800 inExhaust Valve1.430 in1.520 in1.520 in1.520 in Exhaust ManifoldCastCastCastTubularIntake Manifold @ TBStraightAngledStraightStraightThrottle Body50 mm65 mm Hitachi65 mm Hitachi65 mm HitachiMAF?AC DelcoAC DelcoAC DelcoThermostat195°195°180°180°Oil5W-3010W-3010W-3010W-30Oil Pressure @ OT50-65 psi @ 2400 rpm60 psi @ 1850 rpm60 psi @ 1850 rpm60 psi @ 1850 rpm Flywheel Horsepower160@4500 rpm200@5200 rpm200@5200 rpm200@5200 rpm
Each Cylinders compression is @150 PSI!
Old Mar 25, 2014 | 12:13 PM
Griffindor's Avatar
Stump thank you so much. That is an awesome find. The people on this forum never fail to amaze me. Thanks again!
Dstevens
Nov 17, 2014 05:18 PM
jasonsmith
Nov 15, 2011 11:36 AM
78montecarlo
Apr 22, 2011 10:19 AM
bryns96z34
Nov 21, 2009 07:49 PM
Phenomenon
Sep 3, 2008 08:06 PM
