Compression question.
Hello everyone. I have a 96 monte Z34 with the dreaded 3.4V6. The timing belt broke not too long ago and I got lucky enough to replace it and it still run. However, I have a cylinder 3 misfire. I had replaced the spark plugs with autolite standard plugs in stead of the ac delco platinum against my better judgement. I did not replace the plug wires. I took one easy step and tried a new coil on the cylinder but it did not fix the problem. My next step is to check the compression then if its good, replace the wires. I was wondering if anyone could tell me what the compression should be, or even if anyone has any other ideas. I have narrowed it down with nothing but the cyl. 3 misfire code its setting. I also wondered if it may have to do with the type of plug I used. I do not have a manual for it yet so I was hoping someone on here may know the compression specs. Any help at this point would be appreciated.
6th Gen ('00-'05): Compression test question
Dstevens
Nov 17, 2014 05:18 PM
78montecarlo
Apr 22, 2011 10:19 AM
Phenomenon
Sep 3, 2008 08:06 PM
