Compatible Transmissions
Old Oct 8, 2008 | 10:04 PM
Badazgt's Avatar
Default Compatible Transmissions
Hey guys,
I'm new to the forum and am going to be asking a lot of technical questions. My girlfriends got a 2000 Monte Carlo SS with the 3.8L motor. Her transmissions going out, and I've heard that this is common on the Monte Carlos. Is there a rebuild kit for them? Or is it going to be easier buying a different transmission? What years are compatible an what makes?
You guys have been there so whats the best route?
Thank you,
Colby
Old Oct 9, 2008 | 01:41 PM
Teacher's Avatar
Default RE: Compatible Transmissions
I know you are look for the best economical solution, but I would still look at having a local shop rebuild it with a shift kit and upgraded internals. Buying used tranny's is like rooling the dice. Unless you get from someone you know or with a warranty there is no guarntee that it will last.
Old Oct 11, 2008 | 12:33 AM
Badazgt's Avatar
again thanks teacher!!
I have considered the vary thing you say, we may get the same caliber of transmission we have now...
however, this is a daily driver and we need a fix
years and other variations of transmissions would be nice!!!
Old Oct 11, 2008 | 06:24 PM
rysZ34's Avatar
Any 4T65-E trans that fits a 3800 series II will fit your car. ) I agree with Teacher...do a rebuild.
Old Oct 12, 2008 | 10:19 AM
Badazgt's Avatar
thanks
what are some examples of cars with that tranny??
Old Oct 13, 2008 | 11:28 AM
I'd contact moradpartscompany.com and see if they have any trans available. They usually have some short warranty. Either that or you could look on the forums for a lower mileage used one too, but as said above- its possible it has been abused.
Old Oct 13, 2008 | 01:49 PM
Badazgt's Avatar
thanks...
im learing quite a bit about this transmission
ttt
Old Dec 21, 2009 | 08:57 AM
tonycanuck's Avatar
trying to do that same thing myself, any 3.8 ltr tranny????
Old Dec 21, 2009 | 09:18 PM
70monte1's Avatar
Originally Posted by Badazgt
thanks
similar year Grand Prix's, Buick Regals, Oldsmobiles, pretty much any GM car that has a 3800 in it.
Wayne
Old Dec 22, 2009 | 11:23 PM
DESS03's Avatar
actually u cant just use any tranny from any year 98-02 are only interchangeable with those years 03 is a whole nother beast on its own 04-05 changed again 06-08 have different electronics altogether then u have to look at the 3 different gear ratio u can get along with the hd or non hd tranny its a pita unless u mach build codes trust me i just went throught this looking for one =for my car i lucked out and found another 03 tranny with 1k miles on it for 300 at a salvage yard in kentucky these cars had more options than u can dream of
MONTE2000SS
May 22, 2012 09:32 AM
Swinker
Aug 23, 2011 09:58 PM
brokensmile3800
May 2, 2011 10:11 AM
seanzyyy
Apr 24, 2009 03:48 PM
Endo
Nov 11, 2007 03:09 PM
