Committed to a 3.4 to 3.8 swap
Used L36 with Engine could be purchased for $600 - $1000
(Again just best to find a totalled car, at least you can part that)
ZZP Z3 Turbo = $2400
Built Transmission, just send your transmission to tripleedgeperformance.com, shouldn't cost more than $1500
So that's... almost $4500??
I found a L67 engine and trans at 88k miles with all attached accessories for 3k without shipping.
Newgmparts had a NEW l67 engine w/o an SC for 3200.00.....?
The stage one turbo kit from 3800performance is 3199.00
The intercooler is 1099.00
A built trans mission would cost around 4k right?
that puts me at 11k min. WOW that adds up fast...
With all that how much power to the wheels am i looking at?
(yes i know some other odds and ends are needed too)
Secondly, I'd definitely scrap buying a new engine- you're wasting a ton of extra money for nothing; you'll end up with an engine that will far outlast the car. Since your car is already high mileage anyways- I don't see any sense in getting a brand new 0 mile engine- all the other electronics, suspension, body etc will start to go long before the new engine does.
As I, and others have mentioned above- spending $3k for a complete powertrain is way high. I'd bet if you look hard enough, you could get a decent condition 98/99 GTP with about 100k on it for little more; then either just drive that- or part the car out and make back some money- and still have the powertrain left.
Next- forget the cartooning turbo kit- get the ZZP or stattama kits (Z3, Z7, or stattama in order of price and performance).
Next- as far as the trans goes, you don't need a $4k transmission to handle 325whp. The base ZZP trans is $1600 and is rated for 13.0 in the 1/4. Adding the $400 torque converter lowers that to high 12's. Adding a $325 input shaft to that drops it to mid 12's. Adding a $400 single chain conversion to that drops it to low 12's. You can obviously keep going- but thats only $2725 for a trans rated for low 12's. All the expensive, full replacement parts are really only needed with the more extreme setups.
The SUPERCHARGED route:
Newgmparts had a NEW l67 engine w/ SC for 3700.00.....?
This set up is looking like a starting price of 8k
I have been reflecting... If i thought the bone stock 3400 was quick.... then some 'moderate gains' would probable make me happy lol
I can see $5000 or so
$5000 is going to add a lot of money for mods; heck for that kind of money, maybe you could just look into a decent mileage L36- I bet you could get just the engine alone for $500 or so with decent mileage- then spend $2000 on the base ZZP trans (thats including $400 for the core you wouldn't have)- and $2500 for the Z3 turbo kit and you'd be set for awhile. Upgrade it with an intercooler and other mild mods later, and it would be a blast to drive.
I would like 325ish whp. is this do able any where near my price limit?
Gettin closer to the decision.
I cant seem to a decently priced powertrain.
How much WHP would i be looking at with either the Z7 or the Z3?
So my first step in the process would be finding the powertrain. (if im doing a turbo setup, does it matter what engine i get? L67 or L32?
next, send out the transmission to zzp for the upgrade?
http://www.zzperformance.com/grand_p...=150&catid=105
What upgrades to the trans would i need for each set-up? Z& and Z3?
"Standard to ALL ZZP transaxles are:
We offer a complete series of upgrades which are priced (when buying a transmission) as follows (please call to upgrade when placing order):
245mm ZZP high performance torque converter $350
Stock flex plate for 245mm converter $40
Single chain gear set with 3.29 or 3.69 gears $450
VSS reluctor wheel for gear changes $50
ZZP input shaft 4340/300M $325/$400
ZZP output shaft (gun drilled or solid) $190
ZZP pump shaft $110
12 month Extended warranty $299"
This came off ZZP's page.
Then i would need to up grade the new engine? New Cam correct? What other upgrades? TB? Would i need new or upgraded fuel injectors?
Anything im missing?
Then order the turbo kit. And possibly an intercooler? what kinds of gains would i be looking at for adding one? Is it better for the set up(regardless of the power it adds)
As for the turbocharger itself, Is the one in the kit a good one? i have heard about ceramic coated turbines to help reduce stress and spool up time... are either of the turbos in the kit like that? or is that a huge price jump to get one. if its even necessary?
I also see some expensive wastgates on the zzp site? are they any better than the one in the kit? Its just a pressure release valve to prevent over spinning right? Does the "mm" size make a difference?
The kit doesn't say it comes with a Blow off valve. That is a necessary part of the kit isn't it?
Back to the "making it happen" process
After i order the kit, Then i would need to do the engine swap before i install the turbo kit? or install first?
Question area:
I have an aeroforce gauge, it hooks up via the ODB2 port. Will it be able to monitor the boost even though the car
originally didnT have that ability? i think i would want to add a designated boost gauge Though.
The kits have an optional manual boost controller. Is it like a **** or something you can use to change the psi of boost or is it a under the hood to change it thing?
I think i might want help doing the swap and install as it will be my first... I dont even know who or what kind of shop to look for to get said help... Any suggestions. I live in Tampa, FL lol.
AND I DONT MUCH WANT TO DRIVE TO ZZP IN MICHIGAN TO GET IT DONE!!!!!! LOL even though i think that would be the place to get it done...
- All new Raybestos clutches
- New solenoids as needed
- New filter
- New sleeves, bushings, bearings and seals
- New bands
- New Borg Warner HV-093 chains
- Upgraded input speed reluctor wheel
- New valve body on shipped transmissions
- Differential gears and pinion shaft checked for wear
- Damaged or worn parts are replaced (bad differentials, or damage to the casing will be billed separately)
- Custom shift kit
- Forward bands replaced with high energy green bands
- Externally adjustable line pressure (ZZP exclusive!)
- Hardened 4th clutch shaft
- Steel channel plate gasket
- Upgraded TCC apply valve
- Differential squirter (ZZP exclusive!)
- GM DEXRON VI transmission fluid
ZZP pump shaft $110
Question area:
If you have some time to wait- search all the major 3800 boards- clubgp, 3800pro, the various other major forums for cars with 3800s, ebay, craigslists within driving distance.
Then also expand your search to include not only powertrains, but also separate pieces (ie getting a trans from one place and an engine and other parts from another)- also look for totaled cars, bargain days at local junkyards, or cheap whole cars from police auctions, repos, etc.
It took me months (probably half a year) to find my powertrain, I passed on probably 2 other deals to get the price and mileage where I wanted it- and still had to drive 11 hours to get it.
With an L67 or L32 they claim an upgraded intercooled kit to do 400 hp.
The bad thing is, there are too many variables here- will you start with an NA or SC 3800; will you go IC'd or not; which turbo will you go with? Those all change the game drastically.
The other nice thing about getting an L36 over an L67 would be that it probably gives you 20x the choices in selection- the L67's only came in a few GM FWD vehicles- and even of those, only the highest trim levels got the L67. The L36 was used in a lot more vehicles, and made up the bulk of the trim option levels- so there are tons and tons more out there.
The base Z3 kit comes with a BW 56mm turbo good for 550 crank hp- and they offer a $500 extended tip option to raise max power potential up to almost 600 crank hp.
The Z7 kits all come with a 62-1 which has long been a popular 3800 option, and is proven good to an easy 650 crank hp.
The stattama kits are the ones that have all the turbo options from a T67 to a T76 BB- but a fully optioned stattama kit alone is over the price of your budget for your whole build.
Basically, anybody who says they'll come help for free/cheap- don't count on them at all. While I'm on this topic- I hope this isn't your only car- you also need to be prepared for that what if's- what if the "new" engine you got is scrap; has spun bearings or is seized- or the built tranny won't budge due to a simple installer error- or you simply can't get the car to run due to electrical issues after the swap? You need to have something else to drive in case it sits there for awhile. I know at least 3 people that have sold their swap cars because they simply couldn't work out the bugs or get it running, and ran out of money with no backup car. I know its a simple- mostly plug and play deal; but we're still talking about fairly advanced mechanics here- its definitely no oil change.
I think I got all the questions...
Im back.
Sorry for my absence. I moved and didn't have internet for a while.
After reviewing my budget, i just cant see myself putting in thousands and thousands of dollars into this car. I think i would be better off getting a S/C'ed 3800 and get around the 200 WHP mark.
And Possibly do some mild to moderate mods for a good 50 or 60 WHP more.
I think that would keep me satisfied, so i can save up some real money to drop into my old muscle car. its a 1970 Grand Prix it needs a lot of work.
Would i need to do a built trans to handle 250-275 Whp?
Random Question... I have a friend who knows a friend who totaled his SS, sadly the front end is GONE. he said he would sell me his SS gauge cluster for 40 bucks... Will it work on my LS wiring harness? Will all the gauges work?
So im still looking for a decently priced drive train. and trans.
Which model engine would be best for my to be mildly to moderately modded SC setup?
L67, L32, L36...?
the L32 created the most power b/c of the gen 5 SC and the lower compression in the bottom end right?
Thanks for your ongoing help and patience guys.
L67, L32, L36...?
A stock transmission should be fine with under 300 WHP.
Are your gauge clusters different in appearance? Theoretically, it should be able to be swapped out - the interior harnesses should be the same.
L67 swap would be simplest, unless you plan to rebuild the top end before the swap. In that case, you might as well get an L36.
I agree, stock trans will be fine. It won't last forever; but you should be able to get near stock reliability. 250 whp is just barely over what a normal full 3.4" setup makes, so you're not really going to be pushing the engine that hard.
L36 will be more work because you'll have to buy all the SC top end parts to swap onto it. L32 will be a little more work because you'll have to convert throttle bodies, and switch the fuel rail out and such. L67 will be the easiest swap, and will be easier to locate than an L32. Sure you're going to start out down on power a little- but you could always just get the supercharger ported, and have the same effect as getting an L32 off the bat.
Not sure about the gauge cluster.
Gauge cluster WILL work, however not all the gauges will work.
But, you have to sign a disclaimer, get the mileage transferred over properly, and I don't believe the oil gauge will work.
and the search continues
Awesome. I'm keeping my eyes open for an L67 now.
Did all the L67 come with a SC?
Also does the Trans need to be from the same vehicle as the engine?
Do i need to replace the axle up front too? same donor vehicle?
Wiring harness for same vehicle too?
Gauge swap. Chibi, so the oil one wont work, is that because i don't have a 3.8 engine and harness and pcm yet? or will it just never work?
