5th Gen ('95-'99): Checking trans fluid
Old Feb 2, 2013 | 10:30 PM
Zmonte34's Avatar
Default Checking trans fluid
So this is going to sound stupid, but I check the trans fluid while idling and it barley hits the dipstick but when off it reads over full. So i had added atf but it never raised the level when idling. When is the best time to check the tranny fluid?
Old Feb 3, 2013 | 12:27 AM
nitehawkjcb's Avatar
You're supposed to check the tranny fluid with the engine and transmission at operating temperature, in park.
Old Feb 3, 2013 | 10:12 PM
Zmonte34's Avatar
That's what I thought so where is all of the tranny fluid going and what I the correct amount of fluid?
Old Feb 4, 2013 | 09:01 AM
While warmed up idleing in park...
If its just touching the dip stick.Your approximately a quart low......add 1/2 a quart at a time til its at the full mark on the dipstick...
Old Feb 4, 2013 | 09:55 AM
03SSLE's Avatar
Take the vehicle out for a drive and bring it up to full operating temperature.
Park on a level surface, and with your foot on the brake run the transmission through the gear range (pausing for 10 seconds or so in each gear) then put the vehicle in park.
With the engine still running pull and wipe the dipstick, then replace it.
Pull it out again and make note of the fluid level.
It should be within the cross-hatch pattern on the dipstick.
If not, add a little fluid and run the transmission through the gear range again.
Wipe/check level again and (if needed) continue to add fluid/check until the fluid is at an acceptable level.
If you continue to lose fluid the pan/lines/radiator need to be inspected for leakage.
Old Feb 5, 2013 | 02:27 PM
Zmonte34's Avatar
the only problem i have is i have already added 2.5 quarts and it still remains on the same spot on the dip stick and i cant find or see where it might be leaking from which i dont think it is.
Old Feb 5, 2013 | 02:39 PM
03SSLE's Avatar
Is this problem with a Z34 Monte or an S-10? If the S-10, is it 4x4? If it is it could be that the seal between the tranny and transfer case failed. That would allow the fluid you're putting in the tranny to pass into the transfer case. Pull the level inspection plug in the transfer case, and if fluid starts pouring out you found the problem. If this is for a Z34 then I'm at a loss for an answer. If you were 2.5 quarts low I'd imagine you'd have noticed some erratic shifting...
Old Feb 5, 2013 | 07:28 PM
Zmonte34's Avatar
It's in my 96 z34
Old Mar 10, 2013 | 11:20 PM
Zmonte34's Avatar
So I drove the monte today for a mile if that and I parked it and a few minutes later I look under the car and there is tranny fulid runny down the driveway WTF I'm confused
Joe Bloggs
Feb 19, 2013 02:09 PM
deezdrama
Jun 7, 2012 08:01 AM
04IntimidatorSS
May 31, 2012 08:10 PM
echolmberg
Oct 22, 2008 12:17 PM
rchurch
Mar 17, 2008 04:25 PM
