Check Engine Code P0742 TCC Solenoid Stuck On
Old Sep 25, 2011 | 04:52 PM
StrongTakeover's Avatar
Default Check Engine Code P0742 TCC Solenoid Stuck On
My check engine light came about a weak ago coming from Iowa so I went and had it checked out my Autozone and the code they gave me was P0742 which is my torque converter solenoid stuck on. I was wondering how much does a repair like this normally cost?? Should I go to a CHevy dealer or transmission shop? and should i replace the solenoid by itself or get a whole new valve kit put it??? I heard of things like Lucas transmission oil will help but is that safe instead of replacing the solenoid???
Last edited by StrongTakeover; Sep 25, 2011 at 04:56 PM. Reason: forgot to add question about Lucas
Old Sep 25, 2011 | 05:30 PM
94wrangler4.0's Avatar
Well I ended up having my entire transmission replaced because of that little code. I replaced both solenoids and still had no luck. A seal in the transmission went out and was sending transfluid into the side cover area and shorting the solenoids out. With 85K miles on the trans and the costs of the repairs I opted for the new trans.
Old Sep 25, 2011 | 05:57 PM
whoa thats crazy it was shifting hard that day but since then i havent really noticed anything maybe a little loss of power but no hard shifts. Hope I dont have to get a whole new trans because i dont have new trans money
Old Sep 25, 2011 | 05:59 PM
nitehawkjcb's Avatar
Hopefully it's just the solenoid, just be prepared to pay a lot in labor
Although it's easy to replace the solenoid
It's just difficult to get to it, you either need to pull the engine/tranny, or lower the cradle and drop the tranny
Old Sep 26, 2011 | 08:44 PM
nervous as hell about this i really want the car to last me a while
PhillyZepHeather
Apr 30, 2015 09:09 AM
Joester16
Dec 2, 2013 11:48 AM
killerBee
May 4, 2013 12:45 AM
Ds 01 MC
Aug 20, 2008 05:58 PM
Suppoko
Apr 24, 2008 06:30 AM
