Cheapest Scan Tool
Old Sep 19, 2012 | 10:02 AM
Shandley's Avatar
Default Cheapest Scan Tool
Greetings,
I am going to be doing a bunch of PCM swaps over the next year or so. I want to be able to perform the CASE relearn P1336 Crankshaft position relearn procedure. I don't need the scan tool to do anything else. What is the cheapest scan tool out there able to perform this procedure?
Old Oct 16, 2012 | 07:40 PM
MonteLSV6's Avatar
Originally Posted by Shandley
Greetings,
As in a scanner to monitor your engine? Or a scanner as in to modify the PCM codes?
First Question: Scangauge 2 (if you don't want to shell out $160-175, grab "Torque" or android market, or iOS appstore)
Second Question: I don't have any idea lol sorry man :-/
Old Oct 17, 2012 | 08:14 AM
Pretty sure you can only do that with a Tech-2, they are not cheap.
why a bunch of swaps? Why not just purchase tuning software
Old Oct 17, 2012 | 11:35 AM
Mike 00LS's Avatar
You can do it with other scan tools, I asked my mechanic in advance before I installed my Overkill Tune in the event that I needed one (which I didn't). I don't remember the name of the one he has, but that one wasn't a cheap one, either.
But bottom line, a cheap one won't be able to do the relearns for you, they're really only good for clearing codes or monitoring various engine specs.
Old Jun 11, 2013 | 09:04 AM
z34phoenix's Avatar
the aeroforce Interceptor not only scans but is able to do case learns now. they are like $250 new and you can find them used. I had a Scan gauge 2. I got it when my first aeroforce screen died because of many many hot florida summers. the aeroforce updates so much faster then the SG2. So i ended up sending in my AF to be repaired... something i should have done in the first place. there is just no replacement for the AF. If someone is going to be doing some heavy mods or tuning their car right to the edge of Knock. you must have one.
Old Jun 11, 2013 | 06:14 PM
Have you done the case relearn? I'm curious to know if you have succeeded at it and how difficult it was to do? I've been reading a lot of stuff online and haven't found a clear answer as to how easy and if it was successful. Please let us know more if you could, thanks.......
Old Jun 12, 2013 | 09:42 AM
z34phoenix's Avatar
No I have not had to perform a case learn. Not only does my AF do the case learn, but my powertuner does it as well. From what I know the AF walks you thru the steps on the screen. I know you need to keep the rpm at 4,000 for a specific length of time and do what ever else it says. I plan to do a cam next year and will be replacing my cps along with timing chain, so I might need to do this some time. My understanding is that it isn't very hard to do.
aspiringthomas
Nov 4, 2011 11:59 AM
nugzo
Apr 27, 2009 07:22 PM
SSmokybear
Apr 25, 2008 06:13 PM
maclawa
Dec 18, 2005 02:37 PM
