Changing out the Ignition Coil Pack
Old Apr 15, 2013 | 11:57 AM
Originally Posted by PacerSS
If you keep the ICM and bolts from the original coils I suppose it would work
GM used 2 different bolt lengths that I have seen and the length was dictated by the ICM (the L36/L67 I've always seen same length and pitch, but GM may have had mid-generation changes I have not seen) and the 3100/3400 had another length (but same pitch.
but then again you're swapping the same part for the same part
Sir, we're going to have to agree to disagree. The L36/3100/3400 through all generations/years used the same exact coils. The L67 from my knowledge for all years (I believe spanning '96-04) had a completely different coil. You can validate it by a unique part number and underneath these are the onl coils with blue plugs to connect to the ICM.
When people do top-swaps, they typically don't change to the L67 coils because the gains are minimal.
But these coils are different. I have 3 sets of coils in my garage (from L36 and two 3400's all the same part numbers) and L67 coils on my Monte, Grand Am and wife's Impala that do not match the original coils.
As I said, if you still don't agree, that's fine, again, I think we can safely agree to disagree.
Brendocee55
Mar 31, 2016 07:41 PM
f16fixr
Oct 9, 2014 12:55 PM
Cowboy6622
Mar 21, 2011 08:00 PM
nebstewart07
Aug 31, 2010 11:00 AM
montego
Jul 13, 2009 10:48 AM
