Car now needs oil pan gasket
Old Mar 13, 2010 | 09:26 AM
montechick's Avatar
Default Car now needs oil pan gasket
Ok so im not having very good luck with my car at all this month.. I just spent $600 replacing my lower intake gasket, and a couple other gaskets that they had to replace on the way up. So after that was fix I looked under my car to see that yup its still leaking, so i sent it back over to GM, and sure enough the damn oil pan gasket needs to be done which is going to put me back another $500. i really really wanted to do some stuff to the car during spring but i dunno if thats goina be happening now. Wanted to get a brickyard spoiler, tint front window, tail lights, and paint my rear panel.
Old Mar 13, 2010 | 09:54 AM
monte07's Avatar
on the bright side if you put it this way you are not putting the motor in strain with the oil leaks and spending unwanted money on bottles of oil making sure you have oil. the down side is you have to replace the gaskets i am sorry to hear what is going on. just remember your making your mante last longer when you fix things like that and dont have to worrie as much with the motor letting you down latter on down the road. at least when you do the detailing on it and clean the engin compartment you will know there will be less oil deposits. also less that you have to spend cleaning it when you do detailing but i am sorry to hear whats going on
Xraycatj
Mar 9, 2021 10:02 PM
24_48Fan
Apr 2, 2010 07:19 PM
Chevycarlo97
May 25, 2009 04:30 PM
shanefer
Apr 21, 2009 04:12 PM
koreancore
Jan 14, 2009 04:59 PM
