Car getting hotter than usual
Old Nov 22, 2011 | 03:46 PM
02montecSS's Avatar
Default Car getting hotter than usual
so not too long ago, i opened the cap to my radiator because my car would get hotter than usual, and when i took off the cap, it had was stuffed with some sort of sludge build up.i did a regular water flush and it ran good for a few months. The problem returned and theres some sort of sludge build up again under the cap. Also, the other day, after i parked, the water inside the container for the coolant was bubbling or boiling.I bought some flush for the radiator and block and a new bottle of coolant, does anyone know if this will solve my problem?
Old Nov 22, 2011 | 03:48 PM
You maybe are experiencing a problem with air getting into the system.
I would do a complete flush, run with water, flush, run with water, flush, cycle that for a few times, then Fill with a 50/50 mix and fully bleed your system.
Old Nov 22, 2011 | 03:51 PM
02montecSS's Avatar
how do i bleed the system?
Old Nov 22, 2011 | 05:15 PM
After you fill up the system, on the thermostat housing is a bleeder valve, you start the car, unscrew that valve with a towel around it and wait for a steady stream of fluid to come out.
Close. Shut off the car go for a drive. Shut it down, Start it up after a little bit and repeat once to make sure.
doeadeer
Oct 7, 2015 12:25 PM
tey216
Jul 1, 2014 02:57 AM
vincenti
Jul 31, 2013 07:34 PM
Tavi07SS
Oct 2, 2009 09:11 PM
moonlitmagik
Aug 27, 2009 06:11 PM
