can you put the corsica turbo on a 3100 monte
Old Feb 3, 2012 | 02:32 PM
tps221's Avatar
Default can you put the corsica turbo on a 3100 monte
i know the corsica had a 3.1l turbo in the late 80's early 90's how hard would it be to pull the turbo off and put it on my 97 monte ls. has it ever been done? and would it help much in the hp department i also wanna modify my aier intake bigger cone better air flow maybe net alittle torque?
Old Feb 3, 2012 | 02:58 PM
zipper's Avatar
I'm not aware of any model Corsica coming with a turbo 3.1. I do know that that era Grand Prix came with one and the turbo took the 3.1 v6 from 135hp to 205hp, so it's possible that you could get a similar gain if you took the setup from a Grand Prix. However, they're very rare, so good luck finding that.
Best air intake would be a fenderwell. You won't really see a difference from installing a bigger cone air filter in.
When was there a turbo in a Corsica?
Old Feb 3, 2012 | 05:07 PM
mrl390's Avatar
Not even the same motor if its the 3.1 V6 they used in the grand prix turbos
Old Feb 3, 2012 | 05:39 PM
tps221's Avatar
well what would you guys say as far as modifying the width of the main air intake?
Old Feb 3, 2012 | 10:20 PM
mwjames's Avatar
as far as i know the corsicas never came turboed but like they were saying the grand prix's had them, it was actually a partnered design with mclarren. I don't know much about turbo's at the moment but i honestly wouldn't do to much modding to a 3.1L, if you want a big hp gain then go to a 3.8 or supercharged 3.8.
Old Feb 3, 2012 | 11:03 PM
Honestly it's not worth your time and money to heavily mod a 3.1 even an intake would require a battery change and washer fluid bottle move or remOval. Assuming this is just your daily driver, it's best to just leave it stock
Old Feb 4, 2012 | 02:31 PM
zzapultimate's Avatar
Agreed. Except I do have a FWI.. couldn't just leave it stock :p
Save your pennies and drop in a L67. That willl be the best bang for your buck.
Old Feb 4, 2012 | 02:35 PM
SupplySgt's Avatar
Turboing the 3100 would give you about the same gains (likely with less torque) than just dropping in a 3800. At least with the 3800 swap you'd have a lot more upward potential.
turbo monte
Jul 26, 2014 08:38 AM
vikesfan
Jan 29, 2014 12:23 PM
9d6mcjeffro
Jul 14, 2012 11:57 AM
joeykl66
Jan 30, 2012 02:58 PM
skylark65
May 15, 2009 09:24 PM
