6th Gen ('00-'05): Buying a transmission for l67
Old 09-11-2018, 11:42 PM
UJustGotSarged5's Avatar
Default Buying a transmission for l67
Heyy guys back here I have acquired an l67 with 100k miles on it for 600 dollars sweet now I need the heavy duty tranny to go with it. I know I need the 4t65e-HD but does it matter where or what I get it out of is it automatically compatible with any l67/5.3? Should I get it Refurbished or used from eBay?
Old 09-12-2018, 12:13 AM
nitehawkjcb's Avatar
Gearing may be different, but that could be tuned... I think they'll all physically bolt up, but you should probably stick with one that was attached to an L67/L32.
Old 09-12-2018, 12:15 AM
will do thanks!
Old 09-12-2018, 08:40 AM
I would be looking for aL67/L32 transmission because the 5.3L V8 has a different bolt pattern. I don't think the made a special block just for FWD cars but I have been wrong on occasion. Good luck
Old 09-12-2018, 09:36 AM
I didn't know the 5.3 transmission had a different bolt pattern. Then again, I'm not all into the car scene like I used to be.
Old 09-12-2018, 10:51 AM
The LS4 has the FWD bolt pattern. IMO that's one of the biggest reasons that their value is so low compared to other LS stuff since they don't have many easy bolt on options for good RWD trans.
Regardless, the OP wouldn't want one anyways as there are other complications and no reason to pay a premium anyways when any old 4t65 will do.
Old 09-12-2018, 02:40 PM
I don't even need the HD version?
Old 09-12-2018, 10:27 PM
No, you don't need the HD. But keep in mind you will need to tune for the different gear ratio. I think the non HD ratio is 3.29 and the HD ratio is 2.93, but it's been a while.
Old 09-12-2018, 10:28 PM
My future plans are 300hp still would the HD still be a good idea?
Old 09-13-2018, 09:12 AM
Do you want a cheap used trans, or a good trans? If you are willing to spend the money, I would contact Dave at TripleEdgePerformance and let him know your build and he will build you a trans.
If you want a used trans, everyone else is giving great information already in this thread
Quick Reply: 6th Gen ('00-'05): Buying a transmission for l67
