6th Gen ('00-'05): Butt Connectors on the PCM Harness
Old Oct 23, 2013 | 07:53 AM
dbaldwin's Avatar
Originally Posted by 03SSLE
IMO you are 'borrowing trouble by using crimp connectors for your repairs. You have already discovered that they are prone to creating problems, so why repeat the mistake? The wires should be soldered and protected with shrink tube. Not only will this deter/prevent resistance in the circuits (which will alter the sensor signal to the PCM)' but it is a repair that will last for years. It won't be long until oxidation and vibration cause your electrical gremlins to return.
IMO Crimp connectors if done correctly are as good as soldering. You can electric/f4 tape them or use shrink tubing. We use crimping for 90% of our repairs on the planes. But if you do solder in and engine bay use silver solder. Stands up to higher heat.
Old Oct 23, 2013 | 09:11 AM
JC Colon's Avatar
Using the butt connectors wasn't the problem. The problem was that they didn't push the wires all the way in and the only crimped the plastic. I pushed the wires all the way in and did 3crimps. One on each end, on the merely and then on the center to ensure a good connection. If done right, crimping is fine. And if your budget is low it's the better than just Twisting the wires together. As with any repair work, the repair is only as the job you do!
Old Oct 23, 2013 | 09:21 AM
03SSLE's Avatar
In certain situations, crimp connectors are perfectly acceptable. I just don't think that the hostile environment under hood is one of them. Heat, cold, moisture and vibration (not to mention the normal oxidation process that occurs between dissimilar metals) will take their toll on the crimp connectors and they will fail. The resistance introduced by the weakening connections will skew the signals being sent from the sensors to the PCM. Then the mysterious electrical gremlins will return. I have seen this scenario play out numerous times over the last 30+ years being an ASE certified mechanic. To each their own, but with JC's intention of keeping the car for a while it just seems to me a more permanent repair would prevent future headaches and the need to revisit the same problem(s) when they pop up again.
Old Oct 23, 2013 | 11:14 AM
JC Colon's Avatar
Mike, I hear and agree with you. I would much rather have soldered the connections and know I will be in there again. But at this point I had no funds and needed to stop the RPMs from jumping up to 2000 every time I hit a bump. Now that I have done this, all my CEL codes are gone except for the O2 sensor bank 1. And I expected that one when I had to replace my Cat a few months ago. In the spring I can go in, solder all the wires one by one and use heat shrink around the connections. But for now, I need to know the car will last through the winter and the NJ. Inspection in Apr. At this point, electrically, now I know it will.
My best solution is to completely replace the harness. But I can't do a Junkyard Day until the spring. The closest Big ones are in Pa. They would be my most likely source for a complete wire harness for an Old2 Monte.
Nas Escobar
Mar 30, 2015 12:23 AM
MONTE2000SS
Feb 29, 2012 09:05 PM
z34phoenix
Nov 1, 2011 11:11 AM
Joe Thomas
Oct 3, 2010 11:34 AM
RickCoMatic
Feb 15, 2008 08:44 PM
