Busted/Defective water pump :/
Old Mar 4, 2012 | 10:12 PM
Mr.Monte's Avatar
Default Busted/Defective water pump :/
so tonight. (approx 15 minutes ago) i was driving with a friend and i hear a "crinkle" noise. he goes.. "what was that?" i go "maybe i ran over a can? or something" we keep driving we hear it again.. then i pray that it wasnt the car.. i pull over. steam is coming from the engine bay. i pop the hood. coolant all over the engine bay. on the insulator in the hood, engine cover, leaking out of the bottom of the car. i began looking to see if a hose came loose or cracked or something. couldnt see well. real low on coolant i have my dad bring me some and i drop it off at the dealership that we always use for service.
i had a new water pump put into my car about a month or two ago. im thinking maybe this was a defective water pump. but the dealership warrantees the part and the work.
any inputs? rough night
Old Mar 5, 2012 | 01:12 AM
Might be a bad pump or bad gasket
Old Mar 5, 2012 | 06:04 AM
Pump, maybe a poorly seated pump gasket, the coolant elbows.
A hit with a pressure tester should reveal the cause.
Old Mar 5, 2012 | 07:51 AM
The pump could be bad or maybe a heater hose blew off. Hopefully it's the pump so the dealership can cover the cost.
Old Mar 5, 2012 | 10:37 AM
Mr.Monte's Avatar
i got a call and it was a coolant hose -.-
im gunna have the system flushed ect. apparently these hoses go often on the monte
Old Mar 5, 2012 | 10:39 AM
Glad it was a simple fix.
Old Mar 5, 2012 | 10:40 AM
Mr.Monte's Avatar
still goin to cost me $$ cause the labor charges are crazyy.
garvir
Aug 4, 2014 11:40 AM
Brooke
Oct 17, 2007 04:35 PM
Jay84SS
Aug 10, 2006 04:46 AM
poboyracin
Jun 30, 2006 04:22 AM
