Bad stumble
Old Feb 21, 2012 | 09:46 AM
You should check the engine for vacuum leaks too. You never know.
Old Feb 21, 2012 | 09:48 AM
twfurst's Avatar
Fuel filter has not been changed recently, on the list to do though. Air filter I believe I did a few months back. On the fuel filter topic, does it require a special tool to remove the line from the filter? I know one end is threaded, but the other is not. Have not crawled under the car to look at it in place, only looked at the filter on the shelf.
Old Feb 21, 2012 | 09:51 AM
No special tool (although everything could be pretty badly rusted). Just need to quick disconnect one side, unscrew the other and replace.
Old Feb 21, 2012 | 09:52 AM
twfurst's Avatar
I had thought this too, as it seemed almost like a vac leak.
Old Feb 21, 2012 | 09:57 AM
03SSLE's Avatar
Yep, just a flare nut wrench for the fittings and a pliers will do the trick. You do need to depressurize the system prior to removing the filter or fuel under pressure will squirt everywhere.
Old Feb 21, 2012 | 10:00 AM
Meh, just undo the gas cap and make sure you pinch the lines
Old Feb 21, 2012 | 10:23 AM
twfurst's Avatar
Yeah, this sounds like something I would end up doing
Old Feb 21, 2012 | 09:34 PM
twfurst's Avatar
OK, replaced the wires and went for a spin around the block. Seemed somewhat better, but won't really know until the ride to work. Didn't get to replacing the fuel filter, started to rain. Tomorrow is my daughters fourth birthday, so most likely do it on Thursday.
Old Feb 22, 2012 | 07:42 AM
twfurst's Avatar
Drive in to work today, 100% better. Was enjoyable to drive again. Never woulda guessed the plug wires being the culprit. Now to do the fuel filter. Aside from the aformentioned method of pinching off the fuel line to keep it from dumping pressurized fuel, what is the correct way to depressurize the system?
Old Feb 22, 2012 | 08:05 AM
Using the schrader valve near the front valve cover and removing the gas cap.
