ABS & Traction Control Light
Old Jul 25, 2011 | 08:29 AM
montecarloman48085's Avatar
Default ABS & Traction Control Light
I have both of these lights showing (constantly). I have checked the connections at the wheels for the ABS, cleaned and re-connected them and the light remains on.....
The "traction control" connections have been ck'd, yet it remains lit.....any suggestions?
Oh yes, I did ck the fuses as well.
Appreciate any help....Thanks!
Old Jul 25, 2011 | 09:00 AM
You'll have to take the car to a place that can read ABS codes (most "free" places can't do this) and find out which wheel hub assembly is messed up and need replacing.
Old Jul 25, 2011 | 09:06 AM
Teacher's Avatar
Just an fyi I had the same issue and I was low on Brake Fluid. Filled up the fluids and the lights have been off ever since.
Old Jul 25, 2011 | 09:16 AM
Odd, when low on Brake fluid usually the only light that comes up is the red BRAKE light on the dash, not the ABS/Trac off.
Old Jul 25, 2011 | 09:32 AM
DRuben's Avatar
My 02 ss is the same. Mine works when it rains im guessing the water does something to it and it constantly vibrates and makes a noise. When its dry its always on as soon as I change gears.
mwmarshall
May 14, 2022 02:43 AM
peteygnyc
May 23, 2021 01:56 PM
Chris s
Jan 27, 2013 04:30 PM
strypergt
Aug 3, 2011 09:08 AM
Bob50th
Jan 7, 2006 09:46 AM
