Abs?
Old Dec 11, 2011 | 06:41 AM
storm311's Avatar
Default Abs?
So I've got the 06 LT, and I'm pretty sure at that year ABS should be standard, but we recently got snow so I was finally able to test it out, and I can just slide all day. There is no info in the Information Center, and I'm not sure where to look for info on why the ABS isn't working.
Has anybody run into this and figured it out? From what I've seen all fuses/relays seem to be good.
Old Dec 25, 2011 | 12:54 AM
storm311's Avatar
Does anybody have any ideas? Pretty sure the '06 LT should have come equipped with abs.
Old Dec 25, 2011 | 01:54 AM
bearbear3_4's Avatar
Even with ABS the car can still slide and skid. If your ABS isn't working your ABS and traction control lights on the dash would be on. As long as you get feed back from your brake peddle your ABS is working just fine, just change how you drive.
Old Dec 25, 2011 | 11:13 AM
Yeah youll slide with abs still just not as far
Old Dec 26, 2011 | 02:36 PM
steelmalu43's Avatar
Its a possibility that you dont have ABS, but i would assume you do considering its an 06. Bear is right tho, if your getting that slight push back from the pedal then it should be working fine, soooo many assumptions im gunna ask a tech at work
khno.29
Aug 16, 2007 04:55 PM
zipsayain
Jun 25, 2007 07:37 AM
TheElabaman
Aug 15, 2006 10:10 PM
tridski
Jun 26, 2006 09:55 PM
Bob50th
Jan 7, 2006 09:46 AM
