Abs?
So I've got the 06 LT, and I'm pretty sure at that year ABS should be standard, but we recently got snow so I was finally able to test it out, and I can just slide all day. There is no info in the Information Center, and I'm not sure where to look for info on why the ABS isn't working.
Has anybody run into this and figured it out? From what I've seen all fuses/relays seem to be good.
Even with ABS the car can still slide and skid. If your ABS isn't working your ABS and traction control lights on the dash would be on. As long as you get feed back from your brake peddle your ABS is working just fine, just change how you drive.
Its a possibility that you dont have ABS, but i would assume you do considering its an 06. Bear is right tho, if your getting that slight push back from the pedal then it should be working fine, soooo many assumptions im gunna ask a tech at work
tridski
Jun 26, 2006 09:55 PM
