96 Monte won't start when warm.....help!
Old Jul 16, 2012 | 10:31 PM
trvsglr's Avatar
Default 96 Monte won't start when warm.....help!
I have searched the forums and did not find anything on this. A couple years ago I bought a 96 Monte Carlo LS. It ran great until recently. When the engine is cool it will fire right up and run fine. But say I start it, drive it somewhere and park it. When I come back to start it it will shake bad, knock and have lots of trouble stay running. If I feather the gas after about 5 or 10 mins if I manage to keep it running it will run fine again. Today I drove it to the mall fine but when I tried to leave it shook and carried on for a while. Then I came home and my girlfriend got off work early, when I tried to start it to go get her, it ran for a little shaking and knocking but no matter how much gas I gave it, it stalled out and would not even try to run. I ruled out the fuel pump, I checked and I have plenty of fuel at the motor. Does anyone know what this problem could be? Thanks!!
Old Jul 19, 2012 | 08:25 PM
handyrabbit103's Avatar
Default Same problem with my 97
That is exactly the same problem I have with my 97.
It would be great if someone could offer advice to us both.
Thanks
Rog
Old Jul 19, 2012 | 09:59 PM
monte06ltz's Avatar
when you try to start it does it try to turn over?
Old Jul 19, 2012 | 10:24 PM
nitehawkjcb's Avatar
Check your MAF sensor, try unplugging it when the issue occurs
Old Jul 19, 2012 | 10:48 PM
SupplySgt's Avatar
Sounds like it could be the MAF to me. Every time I had a MAF issue, it always gave the symptoms after it warmed up.
Old Jul 20, 2012 | 04:02 AM
trvsglr's Avatar
Yes it turns over but refuses to start. Where is the MAF located?
Old Aug 27, 2012 | 08:06 AM
trvsglr's Avatar
I changed my mass airflow sensor and that wasn't the problem. Even though I had fuel at my motor and the pressure seemed to be fine, I stuck a new fuel pump in it and now it runs great again! Thanks everyone for your input!
Knightwolf702
May 14, 2014 07:13 PM
killerBee
Feb 5, 2013 05:38 AM
gkathleenw
Feb 29, 2012 11:03 AM
ChevRev34
Feb 24, 2008 01:10 PM
SouthernMan
Apr 16, 2007 11:21 PM
