95 monte carlo 3.4 dohc engine problem
hello i have a 95 monte carlo z34 and i have oil in my overflow/engine coolant the oil is not milky and there in no oil in the crank case i dont have the slightest clue whats wrong with it. If somone can help me check to see whats wrong with it or possible find a solution to my problem or just float some posibilities my way i'd greatly appreciate it.
Check your trans dipstick then to see if the fluid looks milky pink. I cant remember if there is a trans cooler in the radiator or a PS cooler. If the cooler in the side of the rad is leaking trans/ps fluid then that could explain the oily stuff in your antifreeze. You will need a new radiator if that is the case.
5th Gen ('95-'99): 3.4l dohc engine whine.
sixscarlo
03-04-2012 10:11 PM
Harleyldraper
08-10-2010 08:20 PM
greg
08-07-2010 09:05 AM
smolek37k
11-08-2006 12:41 PM
1997, 34, 95, burning, cardomaincom, carlo, compression, dohc, engine, lot, monte, montecarlo, oil, overfill, problems, test, transmission
