95 monte carlo 3.4 dohc engine problem
Old Aug 1, 2010 | 06:07 PM
Harleyldraper's Avatar
Default 95 monte carlo 3.4 dohc engine problem
hello i have a 95 monte carlo z34 and i have oil in my overflow/engine coolant the oil is not milky and there in no oil in the crank case i dont have the slightest clue whats wrong with it. If somone can help me check to see whats wrong with it or possible find a solution to my problem or just float some posibilities my way i'd greatly appreciate it.
Old Aug 1, 2010 | 08:47 PM
mrl390's Avatar
I would run a compression test to make sure you dont have a blown head gasket.
Old Aug 2, 2010 | 04:53 PM
im gunna sometime soon i think its burnt tranny fluid in the overflow
Old Aug 2, 2010 | 05:27 PM
mrl390's Avatar
Check your trans dipstick then to see if the fluid looks milky pink. I cant remember if there is a trans cooler in the radiator or a PS cooler. If the cooler in the side of the rad is leaking trans/ps fluid then that could explain the oily stuff in your antifreeze. You will need a new radiator if that is the case.
Old Aug 2, 2010 | 05:40 PM
ya thats what im hoping either gunna get a new radiator or my dad was gunna hook up a transcooler from his old race car and bypass the radiator i guess
sixscarlo
Mar 4, 2012 10:11 PM
Harleyldraper
Aug 10, 2010 08:20 PM
greg
Aug 7, 2010 09:05 AM
greg
Aug 5, 2010 04:48 PM
smolek37k
Nov 8, 2006 12:41 PM
