87 monte bigblock chevy
i just finished building a 496 for my car. does the motor mounts stay in the same place as original because it was a ls model with a 4.3 v6 is it in the same place as a v8 would be in those regards thanks
Hi `Azariah,
Welcome to the MCF.
What big block did you use to get 496 ? What was it in before ?
Do you have pictures ? If so, please post.
What else did you do to the engine ? What transmission are you using ? RearEnd ?
Please post more information & it will help our expert member's help on your question(s)...
Wish you good luck and please check back to check on your thread.....
Look forward to additional infor...Thanks
Welcome to the MCF.
Aug 19, 2013 05:39 AM
Apr 22, 2012 07:20 AM
