86' 305 stock engine stuttering :update:
Old Sep 11, 2007 | 11:33 AM
rj's Avatar
rj
Default RE: 86' 305 stock engine stuttering
If your other carb was sputtering it almost sounds like it has issues and is in need of a re-build? Either the accelorator pump was bad or the float?
Newer carbs have plastic floats in them and need replaced a lot more then the old brass floats. Unless the brass floats sprung a leak.
Since you mention you used the same distributor again after you swapped out the carb I doubt the vaccum advance was causing the engine problems.
Graves53
Aug 27, 2014 09:30 AM
intimidator_ss003
Jan 20, 2014 04:56 PM
edw211
Mar 9, 2012 12:52 PM
robc
Sep 4, 2010 08:05 PM
steptoe
Nov 26, 2006 11:38 AM
