82 Monte timing gear question
Old Dec 4, 2011 | 02:57 PM
Bird Boy's Avatar
Default 82 Monte timing gear question
Does a 1982 292cu-in V6 have a steel or plastic timing gear.
Thanks,
Mark
Old Dec 4, 2011 | 04:41 PM
03SSLE's Avatar
It was common practice for the U.S. auto manufacturers to use timing gears with nylon teeth. This was done to reduce engine noise. The aftermarket replacements are often made of steel. Replacing a nylon tooth gear with a steel tooth gear is fine. You might notice a slight increase in engine noise, but nothing overbearing.
Dam20735
May 23, 2013 04:09 PM
turbo monte
Apr 4, 2013 10:01 AM
Dam20735
Sep 19, 2012 05:36 AM
The Popcorn King
13
Sep 19, 2009 03:25 PM
jogasz28
Jul 20, 2006 03:28 PM
