454 engine
Old Jul 17, 2010 | 06:07 PM
popasmurf's Avatar
Default 454 engine
i have a 454 bb chevy mc .i put a 629 lift cam in this car keep in mind it is only 3200 lb car drag racing only. i have a 400 trans i have to keep it 1300 rpm to stay running and when i put it in gear it dies .i have a 3600 stall in this car ...any help with problem
Old Jul 17, 2010 | 09:57 PM
Depending on the other specs of the cam, I could see needing a higher idle to keep it smoother and stable- sounds like its a pretty large cam. As far as it dieing when you put it in drive, does it stumble or anything- or just shuts off the second you put it in drive? I mean can you give it a little gas to get through it, or is it just an instant shut off?
Its gonna be hard for us to tell you anything easily though- I mean it could be a leaking gasket, damage to the engine, improperly tuned carb, electrical prob- there is a lot of stuff.
Old Jul 18, 2010 | 04:13 PM
Assuming you two are not the same person; you really need to start a new thread to get help with your problem. It'll avoid clogging the OP's thread with other info; and it'll make searching easier in the future for others who may have the same question (especially if you include a proper descriptive title).
Old Jul 18, 2010 | 04:43 PM
The Popcorn King's Avatar
to the OP
Have you checked your vacuum lines for any leaks?
Just a thought.
mowparz
Dec 20, 2013 09:42 PM
scammer
Jan 21, 2009 10:09 PM
ChicoChef530
Oct 7, 2007 06:41 PM
chevydude76
May 4, 2007 08:56 PM
sixty4
Feb 3, 2006 08:31 PM
