3800 motor-tips and info
Old 01-03-2010, 05:08 PM
Cowboy6622's Avatar
the manifold problem i thought was on the 3400, not the 3800.
Old 01-03-2010, 06:35 PM
Enzo354's Avatar
STILL SLOW
No the 3800 has been known for it as well.
Old 01-03-2010, 07:10 PM
I don't know anything about 3400s, but the crappy lower intake manifold gaskets are big, known problem on the 3.8L (including both of mine).
Old 01-03-2010, 07:29 PM
Originally Posted by SUPER SPORT MC
I got a 2000 mc ss with a stock 3800 motor, what are some tips or pointers on what i should change or replace to prevent feuture problems? Im saying like **** thats a common problem on these motors and want something better to replace it first the right time
You should get a Chilton's manual, a voltmeter and bookmark this site to help you sort out any problems you may have in the future. Use the search option first but anyone will be more than happy to help you out with any ?s/problems. Welcome 2 D Forum!
Old 01-04-2010, 08:06 AM
MAMONTE's Avatar
Yea intake gaskets on the 3800 are crap. As well as the 3400...but the 3400 also throws in head gaskets too. The 3800 only has problems with the intake gaskets. Once you replace the gasket, just start changing your coolant on a regular basis, and you should be good.
In my experience with the 3800, lots of the sensors on the engine fail, when they really shouldnt. (crank sensor, knock sensors (x2), oil pressure sensor). And these sensors can be pretty expensive to replace.
Other than that, the 3800 is a solid engine just like everyone else has said.
Old 01-04-2010, 09:51 AM
I agree with that. I've had the MAF sensor fail on both of mine.
Sensors are cheap enough though- have the car scanned for free at Advance or Autozone and then head to the junkyard! They're usually $5 or so each from junked cars, so pick up two in case one doesn't work.
Old 01-04-2010, 09:54 AM
I have a 10 year old car (almost) and it's over 165,000 miles with that engine.
It's a solid engine. I hardly have any problems. Just keep on the regular maintenance!!!
Old 01-05-2010, 07:46 AM
SUPER SPORT MC's Avatar
[. Replace them now if you want the car to last forever. Failing to replace a leaking lower intake manifold gasket can result in your motor being toast if/when coolant gets into your crankcase and makes you spin a bearing.
[/quote]
SO HOW CAN YOU TELL YOU SPUN A BEARING??
Old 01-05-2010, 08:26 AM
You'll know. LOL
Starts with a hollow, thumping sound from your engine that gets worse...then you get terrible engine noises, then you lose power/the engine locks.
Old 01-06-2010, 06:45 PM
Just don't buy the one from the parts stores- when mine went dead on my old gtp, they wanted like $150 + core! Luckily I had the LS2 MAF laying around on my monte to stick on it...
Quick Reply: 3800 motor-tips and info
