2007 Monte Carlo SS
#32
I really like my car now that I've done all my work to it. However... There is another turbo kit available. Squire Turbo Systems is able to do a turbo on ANYTHING and they will help design the kit according to your budget needs. I LOVE the CARTUNING.CA system, but I know it can be a little on the pricey side. Because the LS4 shares the same basic architecture as the LS6 (I have the same heads as the 6.0 GTO) a supercharger is possible. The only real problem you would encounter with the supercharger setup is the hood clearance and the tuning. The 4T65E-HD transmission is definitely the weak link in these cars. Either of these options should be thought about in depth because none of the options are a quick bolt-on deal. Good luck and congratulations on getting a great car!
#33
theres another company that did a group buy recently on tech for a turbo setup on the ls4. they had a link on facebook and everything. good numbers and a little better price. i think the problem with the blower would be the belt set up since the ls4 runs a different pulley set up.i dont think hood clearance would be that huge of a problem.
#34
So I am looking for a little more info on the turbo. Excuse my ignorance but does the intercooler mount in front of the radiator? Also, if this has water meth injection, where does the tank mount and how often does one have to fill?
Thanks for the info
Thanks for the info
#35
If you have any other questions about the install- they do have the entire install instruction guide posted on the web site, literally with step by step directions:
http://www.cartuning.ca/products/wbo...stallation.pdf
Granted, I believe that's on a GP GXP, but its 99.9% the same procedure.
#36
When I brought my 06 SS new; I did not see a supercharge option either (or I would have gotten that option)
#38
It is the same car, and the same engine. Your install may be a little different when it comes to mounting the IC and stuff, but the rest would be identical. If you want to verify 100% for sure, then you would be best to call or email them directly since they make the kit:
If you are looking to purchase a product, please contact the dealer of your choice. If you have questions about kit compatability with your vehicle, or any other questions which will help you with your purchase decision please contact sales@cartuning.ca
Please be patient and wait one to two business days for a reply by e-mail, otherwise call (888) POWRFUL.
Local customers please call (416) 863-TUNE.
#40
i thought 07 has a different ecm in it. diablo doesnt support the 07s ecm. the only difference would be tuning. ive never looked at there stuff, but im hoping the kit would come with a tuned ecm.
Also, the kit specifically lists this in 'whats included':
Custom Reprogrammed PCM and TCM adjusts for fuel/timing/shifting/etc
