2006 Monte Carlo SS Transmission 76000 miles
I bought a used 2006 Monte Carlo SS about a month ago and the transmission is slipping. It doesn't slip all the time, just once in a while at take off in 1st gear. Will I need a rebuild or is it another issue??
Sorry to read about your problem with your S.S.
Do you have the past maintenance records on your S.S. ?
Do you know if the fluid/filter has every been changed ?
I would seek out the best professional transmission person that you can on this problem...I hope it's just needs transmission service...
If the previous owner(s) abused your Monte before you purchased it, it could be the transmission is going
I hope that is not the case, but that is why it is imporant to find a good shop to check it out...Good Luck 4-Sure
Go and get the filter and fluid changed and see if it helps. Make sure they use really good quality products.
DO NOT MENTION THAT IT SLIPS. If you say that, the shop will immediately say it is bad, whether it is or isn't so that they can sell you a new tranny. If it still slips after the change, have TripleEdgePerformance build you one.
i had the same problem when mine was around 68k, i got a PCM and TCM tune from overkill motorsports and it fixed the 1st gear sliping on take off, have not had it come back yet at 96k now. btw im at the strip every thir night. hope this helps.
Achramowicz
May 12, 2013 07:19 PM
SSilver
Apr 28, 2013 01:33 PM
06, 2005, 2006, advertising, carlo, chevrolet, cold, good, miles, monte, problems, slips, ss, transmissiom, transmission
