7th Gen ('06-'07): 2006 Monte Carlo SS Squeak noise while in park and accelerating
So I recently bought my 2006 SS with 57800 Miles on it.
It ran great when I test drove it from the Chevy dealership but now....
In the morning I notice that when I start it I hear a squeek/whistling noise like the belt or something. Its very much rhythmic when idle.
Then when I accelerate the rate of the noise increases.
I commute and after about 15 miles or so the noise goes away.
The car runs fine it just makes this annoying noise the first 15 miles or so of my drive each day.
I took it to my mechanic who is big into chevy and american muscle but the problem is he is about 25 miles away. So he doesn't get a chance to hear the noise and can't diagnose it as anything.
Can anyone help? Why does it go away eventually? Could it be a belt or a gasket leak? Why would it stop?
Thanks for any feed back!
Love my SS by the way. Just want this annoying high pitch squeal to go away.
It's just the belt. It's getting old and brittle. When it's cold it's smaller and tighter, and the little ridges it develops as it wears out makes a noise. When you drive the car, heat expands the belt a bit and the noise will dissipate.
Just head to an auto parts store and pick up a new serpentine belt. But after you buy a new belt and replace this one, keep the old one in the trunk. In the event your belt ever does snap on you, you'll have a backup to tide you over to get somewhere to get a new one. Especially since the belt spins the water pump and power steering.
Thank you so much for your input. I originally thought thats what it was and you just confirmed.
Have a great day. Ill let you know how it goes!
-Conrad
I bought the extended warranty, but no parts have been replaced.
I just had it aligned and my mechanic said the transmission fluid was oddly old looking/smelling so he replaced that as well.
Also need to get my heat door actuators fixed as my A/C is clunking on me.
Was kind of pissed they sold it to me like this after they swear it costs extra money to make it considered "certified" but passed there 100 some odd point inspection!
I hate car dealerships!
I bought it with 57800. I now have 58400. I believe all original parts as I bought this used and not certified at a dealership with no warranty.
If you don't have the GMPP, you will have to contact the agent of your particular EW.
And it would be the idler pulley/tensioner that would stop making noise after 15 minutes of driving or so.
Not the serpentine belt?!
Is it a squeak or a chatter? On my Monte Carlo it would squeak, replacing the belt fixed it. On my Silverado, the tensioner would rock back and forth a bit and make a chattering sound, from metal rubbing the parts behind it.
If you have a can of that serpentine belt stuff in a can that you spray on a squealing belt, hit it with that and if it stops for a bit, you know its the belt. Although that stuff isn't recommended to be used much as it'll actually wear the belt down.
The way I look at it though, at almost 60k the belt is rubber and is probably ready for a change anyways. Plus it's quicker and cheaper than the tensioner to replace. So might as well try that first.
