2006 Monte Carlo LT engine interchangeability
Old Jul 3, 2016 | 08:32 AM
aspiringthomas's Avatar
Default 2006 Monte Carlo LT engine interchangeability
I have a 2006 Monte Carlo LT 3.5 liter vin K. I am curious what year 3.5 liters will fit. Thanks Jeff
Old Jul 4, 2016 | 01:18 PM
I am thinking a 2006-2011 3.5 liter will interchange with minor differences(like injectors etc, I noticed on the cavalier's I worked on they changed the injector plugs but the basic engine stayed the same from 98-02)
https://en.wikipedia.org/wiki/GM_High_Value_engine
LZE[edit]
The LZE 3500 was an OHV flexible fuel engine based on the 3.5 L LZ4 V6 (it can use either plain gasoline or 15% Gasoline and 85% Ethanol, E85) and includes continuously variable cam timing (fixed overlap). It has a cast iron block and aluminum heads. Bore is 99 mm (3.9 in), stroke is 76 mm (3.0 in) for a displacement of 3510 cc (214 cu in). Output is 211 hp (157 kW) at 5800 rpm and 216 lb·ft (293 N·m) at 4000 rpm.
Applications:
2006–2011 Chevrolet Impala
2006–2007 Chevrolet Monte Carlo
2009-2010 Chevrolet Malibu
2009-2010 Pontiac G6
Old Jul 4, 2016 | 01:57 PM
Default 2006 3.5 engine swap to 2006-2011 3.5 engine
Has anyone swapped between models on the 3.5 engine 2006-2011. I have a 2006 monte carlo LT vin K flex fuel and found a 3.5 from a 2010 impala and trying to find out what may need to be changed to install this in my monte carlo
Thanks
LZE[edit]
Applications:
Old Jul 4, 2016 | 06:14 PM
If a member doesn't know I'm sure that any good GM parts department could answer your question...GOOD Luck
GM High Value engine - Wikipedia, the free encyclopedia
Wikipedia
The High Value engine family from General Motors is a group of Cam in Block or "Overhead valve" V6 engines. ... Vue XE AWD (222 hp/220 lb-ft). Note: GM often refers to this engine in its literature as a "3.5L V6 with Variable Valve Timing".3.5 · ‎3.9 · ‎See also · ‎External links
Old Jul 6, 2016 | 10:13 AM
I will be picking up a 2011 3.5 engine with 27K today at lunch for around $500-$600 so I will let everyone know what I have to change to install it in my 2006 Monte Carlo. The guy at the salvage yard said he remembered some of them having different oil pans.
Old Feb 19, 2017 | 04:40 PM
Well I am part way through the process of installing a 2011 impala 3.5 liter into my 2006 monte carlo. I found so far that there is a sensor in the oil pan on the monte carlo that was deleted on the impala. Also the plug for the sensor threaded near the oil filter was different which was probably the oil pressure. So far those are the only 2 differences I have found. So I installed the 2006 oil pan on the 2011 engine and installed the sensor from the old into the impala engine.
Old Dec 17, 2019 | 10:52 AM
Benni Hunnaa's Avatar
Default Advise
LZE[edit]
Applications:
so can use a 2011 vin "k" impala lze engine in my 2009 vin "n" impala without changing computers ?
Old Dec 17, 2019 | 11:47 AM
Jeffs02rwdSS's Avatar
The post is almost 3 years old and the member hasn't been online since their last post.
Mr.Monte
Dec 26, 2011 09:09 PM
alabamamonte
Jun 1, 2008 03:06 AM
Bigg J
Nov 1, 2007 11:42 PM
SoCalSS
Nov 12, 2006 05:58 PM
BeachBumMike
Oct 8, 2006 08:59 PM
