2006 3.9 engine replacement
Old Oct 14, 2025 | 12:31 PM
kingreyna's Avatar
Default 2006 3.9 engine replacement
My 06 Monte finally kicked the bucket. Horrible raddle at startup.
Bought it new and love it still. 186k
Question is, is there any differences on 3.9. I know some of them had displacement on demand. But on the 06-07 monte and impala were they generally the same.
Anything to look out for that wont be compatible?
I'm planning on keeping it till ..forever.
Any feedback is appreciated.
Old Oct 14, 2025 | 03:33 PM
I dont know squat about the 3900s, but are you sure it's not something simple - a cracked flexplate, balancer coming apart, etc? Or is defintiely an internal bottom end issue?
Old Oct 14, 2025 | 04:01 PM
kingreyna's Avatar
It sounds like something banging in there, it'll try to start then popping and other metal noises. A mechanic co-worker says its more like a piston wrist or something like that.
Ill tear it apart this week but doesn't sound very promising.
Old Oct 14, 2025 | 04:59 PM
Oof - sorry to hear!
Old Oct 14, 2025 | 07:45 PM
kingreyna's Avatar
Doing an initial scan, Misfires are on Cylinder 1,3,5
What would cause one side of the engine to go dead with rattling noise??
So it cant be one component of the engine and also cant be 3 different components at the same time either?
Anyone have any idea for this?
Old Oct 21, 2025 | 07:48 PM
Sadly I don't know much to anything about the 3900. I believe I have read the 3900 is the same basic block as the 3100/3400/3500 (not sure if that is true or not).
That is extremely strange to have all the misfires on the same side.... Just wild thinking (ignoring the rattle, focused on the misfires):
- Bad ICM
- Bad coil (I think that uses a single coil)
- Curious if the injectors on that side share say a common ground wire that is not shared with the other side and is broken somewhere in the path.
Wish you luck getting the Monte back on the road.
If you ever decide to part with the car, let me know what you want for those Moda wheels. I would not mind an extra set.
Old Apr 3, 2026 | 12:02 PM
kingreyna's Avatar
Update:
Motor and trans have ben replaced and now hoping for another 20yrs.
I reddit and clean every piece of the replacement engine. Replaced the seals on treansmision.
Now everything is running perfect again. Took me 5 months for everything but well worth it.
Old Apr 3, 2026 | 03:30 PM
Originally Posted by kingreyna
Update:
Awesome to hear. What did you use as a guide? I bought a "new" vehicle the other day so I can do this same thing, rebuild the engine but also the trans. Is 5 months far off from what you originally expected? Run into any hassle?
Old Apr 5, 2026 | 11:19 AM
kingreyna's Avatar
5 months was because winter came and just wasnt able to do much and had my other car for the time being.
I had a friend who just removed and install the motor and trans. He did it in one weekend.
I took me about to 2 months cleaning and resealing everything in my garage. Trans was only resealed.
THe motor and trans had 144k miles as there are not alot of these out there but everything looks good inside. So far everything is running good, fuel trims are good.
maxxpro123
Jan 3, 2015 08:16 AM
wheeler3
16
Mar 19, 2009 10:31 PM
davitto
Mar 4, 2009 09:00 PM
Bigg J
Nov 1, 2007 11:42 PM
06LT3
Oct 12, 2007 08:38 PM
