2003 LS Slipping Tranny?
Hey guys,
As you may or may not know I drive a 2003 Monte Carlo LS, 3.4 in it, resonator delete, u bend delete, flowmaster yada yada, and recently installed the Overkill PCM in it, hoping for it to cure my slipping transmission. My tranny slipped off lights badly, you could feel it want to go but it would slip, so I'd just let off and get back into it and it would be good. Well the PCM didnt help it at all really. Still does it fairly often, and if you dont let off and get back into it and just stay in it, it will clunk when it stops slipping. What could this be? It really worries me, so much that I have began looking into other cars...
Help me so I can keep the monte
Thanks
Thanks
Two Things To Look Into, GM's 4T65E Transmission Has A Common Problem With The EPC Solenoid & TCC Solenoid... If U Check Out My Thred ----> https://montecarloforum.com/forum/ge...a-31698/page4/ This Is The Biggest Problem Known To Cause Shifting Problems, Hard Shifting And Tranny Sliping.... Take A Look Into It
I Myself Received A OBD II Code PO742, I Stop Driving The Car and Look It Up On Line, I Went By The Most Common Options, Its Said That If U Have Transmission Problems With The GM 4T65E Most Likely Its An Electrical Solution (Cheaper Fix) & The Low Percentage Of The Time It's Mechanical (Very Expensive - Rebuild = $750.00 or New = $1300-$1500) But My Problem Was Electric When I Recieved The Code, But Remember Not All Electric Problems Get Pick-up By The PCM.... Somtimes It Can Be A Shortage in Ground or Internal Components....
hollf1
10-20-2010 09:16 PM
recci03
12-09-2009 02:28 PM
