2001 SS AC problems
Old Jul 30, 2013 | 05:06 PM
CityLifeSS's Avatar
Default 2001 SS AC problems
Wassup y'all I'm having AC problems but I just replaced the compressor and reciver dryer last night.... Put 2 bottles of freon in it but its still blowing out warm air...any other suggestions? Thanks in advance
Old Jul 30, 2013 | 05:27 PM
You may want to consider adding a UV reflective dye to find the leak or consult a professional. I replaced my evaporator core (under the dash), as the guidance I had suggested that to be the problem. That still was not it. Final answer was the condenser in front of the radiator (real easy to change too).
Once I had the condenser out, you did not need UV light to figure out the problem..... One corner of it was coated with old, grimy, oil. So when the freon leaked out with the oil, just made a mess of it.
01blackSS
Sep 2, 2013 08:22 AM
Frosty LS1
Apr 28, 2013 11:13 AM
gyolai
Oct 8, 2008 10:17 AM
CHOWEE21
Apr 2, 2008 10:56 AM
oldnumber7
Feb 4, 2008 04:17 PM
